B16A tranny in my 98+ Integra. ***What rear mount do I use?***
Old Apr 7, 2003 | 11:20 PM
F1Spec's Avatar
Default B16A tranny in my 98+ Integra. ***What rear mount do I use?***
Here's the problem I got...
I put in this B16A (S4C) tranny in my 98+ Integra and I have a stock
rear 94+ integra mount. And the mount dont fit.
Do I need a 99-00 SI rear mount or what's the deal?
Thanks a lot in advance.
Old Apr 8, 2003 | 07:07 AM
eg6ajk's Avatar
Default Re: B16A tranny in my 98+ Integra. ***What rear mount do I use?*** (s2geezy)
are you sure you have the right mount? or the right tranny even?
either way it should just work without problems
Old Apr 8, 2003 | 11:17 AM
F1Spec's Avatar
Default Re: B16A tranny in my 98+ Integra. ***What rear mount do I use?*** (eg6ajk)
100% sure it's the right tranny. it reads S4C so its a B16A (or CTR) tranny.
the tranny is mounted on to a LS block that is a 90-93 block B18A. does that matter?
the problem is the rear T-mount, not the rubber mount that's on the subframe.
i got two mounts....i tried both of them. neither of them fit.
help!
ps- if i dont know what to do ..eventually i think imma just gonna drill a hole
or two on the T-mount so i can mount everything back up and drive!
Old Apr 8, 2003 | 12:04 PM
intekragsr's Avatar
I have a Y21 tranny(b16) Will I run into the same problem?
Old Apr 8, 2003 | 12:08 PM
IS3Fifty's Avatar
right... are you sure you telling us the right mount??? If its the tranny mount then you need to use the b16 mount, but if its the motor mount then the LS must fit.
Old Apr 8, 2003 | 01:00 PM
F1Spec's Avatar
Default Re: B16A tranny in my 98+ Integra. ***What rear mount do I use?*** (purek9hybrid)
i am talking about the REAR MOUNT that looks like a T. it bolts two bolts
into the trannt. on on the block and one on the front sub frame.
talked to my friend...he said i need a b16a rear mount..
Old Apr 8, 2003 | 01:52 PM
AZFABULOUS's Avatar
If the T shaped mount you are talking about is from a 94 it will not work, you will need to get the mount that you were talking about 99-2000 si and you should be in business.
Old Apr 8, 2003 | 02:56 PM
F1Spec's Avatar
Default Re: B16A tranny in my 98+ Integra. ***What rear mount do I use?*** (AZFABULOUS)
thanks
Old Apr 8, 2003 | 03:00 PM
F1Spec's Avatar
now i'm getting mixed story.
a friend told me i need a b16a rear mount and the other friend said
it dont matter what tranny i have. all i need is a 94-00 integra rear mount
'cuz i have a integra. hmm...
Old Apr 8, 2003 | 06:48 PM
AZFABULOUS's Avatar
oh **** Iam sorry I read your post wrong. For some reason I was thinking that you were putting this into a civic not an integra. Your friend is right the tranny should not matter the mount that you have should work .
egb16pg
Mar 21, 2007 05:34 PM
integra3586
Feb 15, 2006 09:48 AM
T--Rex
46
Jul 27, 2004 11:46 AM
