First Time Dyno...Help a Brotha Out
First off, I didn't know getting on the Dyno costs so much. I called up Altered Atmosphere in MD and they quoted me $85 for a baseline run (consists of 2 runs). An extra $35 if I wanted the wideband O2 sensor hooked up. This is all Chinese to me and I'm not Chinese.
The per hour rate (which i guess is for tuning) is $100...again $35 extra for the wideband. So here comes the questions.
a.) Are these prices fair?
b.) What difference does does it make to have a wideband 02 sensor connected while doing a dyno run?
The per hour rate (which i guess is for tuning) is $100...again $35 extra for the wideband. So here comes the questions.a.) Are these prices fair?
The price for the baseline runs sounds quite high. The shop I go to charges $50 for two runs.
The tuning price is not that expensive but I don't know how you'd do it without the wideband, so it's not that cheap afterall. The shop I use charges $150 an hour for tuning, if they tune it, $100 an hour if you wrench on the car yourself.
What exactly is the Wideband O2 sensor used for? Is it to get readings and tune for the Air/Fuel Ratio? If that's the case, I would assume I don't need that for a baseline run, right?
Correct. If you're just doing a baseline run the O2 sensor isn't going to be of much use (unless you suspect there's a problem, in which case it will turn into a tuning session).
Is your car stock? If you're just trying to get an idea of where you're at before you mod it, using the O2 sensor is a waste of money.
Yeah, my car is pretty much stock but I got big plans for it just like everybody on this board. I regret not getting in a dyno run before I put in my Icebox.
[Modified by CPR, 6:46 PM 6/22/2001]
BigMoose
Aug 5, 2002 05:47 AM
