my door popper owns me...
Old Apr 7, 2003 | 07:57 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default my door popper owns me...
well today my door popper decided to quit on me.. after i got home and was getting out i had already opened my door. when i went to reach for my ignition i accidently poped my drivers side door. it poped but right after it made a wierd noise and died. i immediatly rolled down the window and closed the door to see if it would pop or not i also tried my passangers side and no luck. i though it could have been my remote. but then i went inside and grabbed my other remote.. no luck. i also tried my emergency relay under my car that i had hidden also no luck. i know its not the remotes now. what else could it be? i bought the car with the doors shaved and the poppers installed so dont flame me for having shaved door handles.
Old Apr 7, 2003 | 08:35 PM
youngkow's Avatar
Default Re: my door popper owns me... (ek9folife)
Could be the solenoid went bad. Can you hear the relay clicking when you press the remote? If so, check the solenoid.
Old Apr 7, 2003 | 08:44 PM
jumpmann23's Avatar
Default Re: my door popper owns me... (youngkow)
i dont hear anything anymore when i click the remote. i really hope its not the soleniod. could it be a fuse? im not sure ill check it out in the morning. this ******* sucks. i dont know what im gonna do about getting to school.
Old Apr 7, 2003 | 08:54 PM
-RedneckDave-'s Avatar
Working
It sounds like a fuse or a loose wire that has shorted out. Start the process of elimination with the power wire for the system and work your way through it all the problem will most likely be simple and obvious.
Old Apr 7, 2003 | 10:38 PM
tnbigdawg's Avatar
Default Re: my door popper owns me... (01accordv6)
do a test and run straight power and ground to your actuators. if they dont move then that's the problem. they tend to overheat if you keep playing with them. they arent made for that.
Old Apr 8, 2003 | 06:58 AM
youngkow's Avatar
If you don't hear any sounds, the relay might be bad, or like 01accordv6 said could be a fuse. There should be a fuse by the brain box underneath the steering column (which is the place they most likely put it), and yeah, do the test like ek9folife said. But since you don't hear anything, your probably not getting any power.
Old Apr 8, 2003 | 02:09 PM
jumpmann23's Avatar
fixed it today. blown fuse. thanks for the help guys/
Old Apr 8, 2003 | 03:20 PM
Working
no prob.
kornerk12
May 31, 2009 07:53 PM
D16Z6racing
Jun 5, 2007 05:32 PM
FK00GSR
Apr 10, 2005 06:32 PM
92SleeperH23
Dec 28, 2004 11:50 AM
es four
May 20, 2002 11:44 AM
