Question about Cold air intake on LS swap for EG
Old Apr 7, 2003 | 07:01 PM
DavidTurbo's Avatar
Default Question about Cold air intake on LS swap for EG
I'm doing a swap on my CX using a 91 B18A1 and was wondering what's the best Cold Air Intake I should use, I was offered an AEM off a 95 Integra LS. Does any one know the difference between a GSR and an LS Intake? Let me know thanks
Old Apr 7, 2003 | 07:06 PM
94HybridEX's Avatar
Default Re: Question about Cold air intake on LS swap for EG (DavidTurbo)
GSR intake would be made for the butterfly manifold that "bends" down behind the motor, so the intake wouldn't fit quite right from the gsr. If you can, try to find a Type-R intake or a Si intake.
Old Apr 7, 2003 | 07:10 PM
DavidTurbo's Avatar
Default Re: Question about Cold air intake on LS swap for EG (94HybridEX)
I'm using the intake from a 95 LS will the Cold air intake from a type r work?
Old Apr 7, 2003 | 07:12 PM
94HybridEX's Avatar
Yes, the reason I said R intake is because it has the largest diameter. But, it won't go down to the wheel well through the stock hole though.
BackSideSA's Avatar
https://honda-tech.com/zerothread?id=457412
this is my thread..... you will need a 99-00 civic si cold air intake. i got pics, check it out
Old Apr 7, 2003 | 07:26 PM
civicmandx94's Avatar
Default Re: Question about Cold air intake on LS swap for EG (HybridHackBatch)
I have a gsr engine in my 94 coupe and I just used an integra cai from ebay. $30.00 and it works great. Good luck and God Bless!
Old Apr 7, 2003 | 07:27 PM
DavidTurbo's Avatar
Man! that intake looks perfect! I'm definitly going to have to go with that! do you know if it will fit the LS intake? and does that guy have any more intakes left?
Old Apr 7, 2003 | 07:29 PM
DavidTurbo's Avatar
Thanks Alot guys, I really apreciate everyones help!
Old Apr 7, 2003 | 08:28 PM
94HybridEX's Avatar
Here's my LS with an Iceman CAI. It's the one made for B-series in 92-95 civic.
Old Apr 7, 2003 | 08:33 PM
SpoonFedHatch's Avatar
if you get an INTEGRA intake, you will have to relocate your coolant reservoir in order for it to fit, regardless of what trim integra (i.e. the intake itself WILL NOT go into the "hole" that the civic has for the stock intake)
just get a $30 intake frome ebay for a 99 civic SI, same pipe diameter, same pipe construction/number of bends, and same material used as AEM
here's mine
[Modified by SpoonFedHatch, 5:35 AM 4/8/2003]
barnie
Dec 4, 2008 04:10 AM
6042nr
Apr 6, 2007 12:46 AM
toeknee360*
Feb 12, 2006 10:04 AM
