thump..thump..thump...thump
Old Apr 7, 2003 | 05:59 PM
BoOsTeD_eK's Avatar
Default thump..thump..thump...thump
Alright I am about to blow a fuse....this damn car I have been working on has this funny vibration stemming from the passenger side...its sort of similar to the noise madewhen you have warped rotors...and it get progressively worse when the brakes are applied. I changed all 4 rotors and pads, master cylinder, passenger caliper, axles...and the damn intermittent thump is still there...still getting worst when brakes are applied...anyone have any idea what this might be?
Old Apr 7, 2003 | 06:35 PM
poison's Avatar
Default Re: thump..thump..thump...thump (BoOsTeD_eK)
it's from the front passenger side only?
Old Apr 7, 2003 | 06:46 PM
non-VTEC's Avatar
worn lower control arm bushings, worn ball joints, worn tie rod end?
check all that stuff and let us know.....
Old Apr 7, 2003 | 07:03 PM
BoostingSnail's Avatar
Default Re: thump..thump..thump...thump (non-VTEC)
Check the wheel wheel bearings...I bet thats your problem....make sure your axle nuts are torqued correctly before you assume its the bearings
fortified55
Suspension & Brakes
Oct 21, 2015 10:29 AM
mltv
Jul 31, 2008 03:30 PM
mysicivic1991
Mar 20, 2007 04:06 PM
ki11a8ee
Oct 5, 2004 10:11 PM
CW_97_ITR
Aug 30, 2004 03:10 PM
