White Some At Idle
Im Running A mini me swap and if i sit at a light and idle for a few min's and then tap the gas i blow some white smoke out but its usually only when i idle for a few mins could this be im running rich or blown Ring? and im also running a Tanabe Cat Back Exhaust with a test pipe
[Modified by nighthunt6, 7:01 PM 4/8/2003]
check the oil cap, look at it, if it has anything other than oil in it..... that could be head gasket(it was for me), the oil had a milky substance in it.
The smoke could just be polution because of the test pipe, as my friends get puffs of white smoke and they have test pipes and no problems with the engine.
From: Northwest Hills of, CT., United States of America
It is most likely condensation steaming off from water trapped in your hot exhaust system. This is normal, Don't panic. Just check the usual stuff, Is it foamy under your oilcap? Does your exhaust smell like antifreeze? Is your coolant low soon after you fill it? Is there oil bubbles floating in your antifreeze? If not then it is just steam!
[Modified by broncoman74, 3:21 PM 4/8/2003]
From: the asshole of america..., upstate new york, USA
[QUOTE]It is most likely condensation steaming off from water trapped in your hot exhaust system. This is normal, Don't panic. Just check the usual stuff, Is it foamy under your oilcap? Does your exhaust smell like antifreeze? Is your coolant low soon after you fill it? Is there oil bubbles floating in your antifreeze? If not then it is just steam!
[QUOTE]
what he said
[QUOTE]what he said
Thanx Guys Ill Check It out i was just worried cause some times when i tap the gas it smells like oil a bit so i thought maybe i need valve stem seals or somthing big cause my block has around 205k miles on it
bpfergu
Mar 5, 2012 05:27 PM
gunterelectric226
Dec 3, 2008 06:49 PM
