how have you shaved the moldings off of your DC2?
Old Apr 7, 2003 | 11:05 AM
streetlights's Avatar
Default how have you shaved the moldings off of your DC2?
i want to take my car to maaco for a paint job...should i shave the moldings off myself or let maaco do it...if i should do it myself, how should i go about it...i think the moldings are clipped on by a couple of clips, im just wondering about how to fill in the holes...anyway...thanks in advance
Old Apr 7, 2003 | 11:20 AM
canuck-mx6's Avatar
Default Re: how have you shaved the moldings off of your DC2? (streetlights)
Weld some metal over the holes, grind the edges down and smooth with some bondo/fibreglass
Old Apr 7, 2003 | 05:00 PM
Default Re: how have you shaved the moldings off of your DC2? (canuck-mx6)
what if i weld the metal in from the other side of the door (door panel side) and then fill the outside with a little bit of bondo then smooth it out...so the bondo is only in the hole? would that work?
Old Apr 7, 2003 | 10:43 PM
96integra20's Avatar
I am actually in the process of doing my own body work right now, i am at the step of shaving the moldings off, and what i started to do yesterday was sand down front and inside of door, make sure down to bare metal, then got a piece of galvonized metal, put the metal in the back, held it in place, then spot welded it from the front, then grind down slightly, then use duraglass, and then normal filler, and walla!!!! hope this helps
503_EF9
Paint and Body
Nov 12, 2007 06:16 PM
ludesrv
Mar 2, 2007 09:59 AM
Eagle16nam
Feb 5, 2006 09:47 PM
OldSchoolHatch
Feb 25, 2003 01:14 PM
IS3Fifty
Feb 20, 2003 06:50 PM
