Neuspeed race springs on stock ITR shocks.
The stock shocks can't handle that spring rate. I have called Neuspeed for the specs on those springs and they are nuts. I forgot the actual numbers, but it's like 2x that of stock. call them and they will tell you the same. In fact, if you call most of the shock manufacturers, they will say that the spring rate is too high for anything they produce BUT they WILL custom valve you a shock $,$$$
You should be pretty bouncy on the streets, due to the insufficient dampers (shocks)
geminis2k
Aug 28, 2003 09:07 PM
Agent STFU
16
Feb 23, 2003 08:31 AM
