Dart Blocks
Old Apr 7, 2003 | 07:31 AM
integra6650's Avatar
Default Dart Blocks
im debating on whether to do a b20 dart block with all the good **** or go with a used block that has to be cleened decked bored and sleaved the 1900 for the block seems like alot but for the quality your getting and the fact youll prolly spend that much between the block and the machine work. does anyone have any good experience with dart blocks?
Old Apr 7, 2003 | 07:58 AM
torr's Avatar
Default Re: Dart Blocks (integra6650)
you'll be pretty satisfied with the dart block. my friends got one. the quality and appearance alone is awesome. the block comes with all the plugs that go on the block, make sure to retighten them. it also comes with mains. on top of the block it has a hole dirlled for the vtec oil. the design of it is basically like a gsr. you need oil squirters too. i would rather buy the dart block only if i had all the miscellaneous parts to go with it, remember it's just the bare block and mains that your getting. if you don't have all the parts then go ahead and buy a b20 or ls longblock, a block that already has the oil pan, nuts, bolts, seals,etc. then just go ahead and sleeve that one.
Old Apr 7, 2003 | 09:25 AM
Default Re: Dart Blocks (torr)
thats my tossup but i think im going to go dart anyway and buy the b20 parts i neeed maybe a little more expensive but the quality will be much better and i wont have to deal with machine shops
Old Apr 8, 2003 | 07:29 PM
turboex's Avatar
I am the one that built the dart motor that torr is talking about, and if you go that route you are better of buying a blown b16 adn getting all the parts of it, like, pan, pump, brackets. If not it will get VERY spendy. We have about 13-15grand in this setup so far.
Old Apr 8, 2003 | 08:10 PM
10K2HVN's Avatar
Default Re: Dart Blocks (turboex)
yeah, very costly..but your gonna want VTEC oil pick-up, windage, and oil pan..not the LS/B20 ones...
Old Apr 9, 2003 | 05:07 AM
Default Re: Dart Blocks (10K2HVN)
are you saying 13-15 on block alone i was expecting 5-6
2 for block
1 for full stock(for various reusables)
2 for aftermarket parts(pistons etc)
1 for all else
Old Apr 11, 2003 | 04:43 AM
torr's Avatar
yeah, 13- 15 alone on the block, not just the block but the whole deal from the beginning to the end.
Old May 16, 2003 | 09:20 PM
B18poweredhatch's Avatar
what exactly does the block come with? someone said plugs but im curious if it comes with a drivetrain or not. and just because they come with vtec holes,you dont necssarily have to go vtec right?dont wantoil pouring out a hole.
Old May 16, 2003 | 09:35 PM
turboex's Avatar
Default Re: (B18poweredhatch)
The block comes with nothing at all, not a single bolt or anything, just the block maincaps and main bolts thats it. The plugs i was talking about are the freeze/casting plugs, these have to be sealed via teflon tape or what ever. The block is a vtec block based of a gsr. Im sure you could run it without a vtec head but why would you?
Old May 16, 2003 | 09:50 PM
Dual Cams's Avatar
i got this for sale.... its pretty much like a dart's block. hit me up, i'm taking whatever is reasonable.... and i'm pretty sure you'll save couple hunder dollars from the darts block
GSR 5/8" Deck plate bare block, comes with 5/8 of a inch deck plate, Brand new GE sleeves, all caps, oil pan, oil tray, and oil pick up, ready to install pistons and rods. This block is good till for 81mm to 87mm bore. also you'll be able to use a bigger crank and longer rods
price: taking reasonable offers
Old May 17, 2003 | 03:27 AM
10K2HVN's Avatar
Default Re: Dart Blocks (Dual Cams)
Beautiful Block! Honestly, if i had a job and some money saved up, id soo buy that block off you!
..but im just wondering..what kindve Deck Plate is that..? Golden Eagle? Are you suppose to weld it down? ..or is it just a gasket in between block and deckplate and gets sandwiched between Block and Head to ensure a seal??? Thanks for a reply..
-10k
Old May 17, 2003 | 07:49 AM
Dual Cams's Avatar
its a golden eagle block, no welding, its a different design than other companys. the reason i didn't want to take it to a shop get it weld it is because i'm scare people might heat up the block too much when they weld it and might mess up the block. and with Golden eagle deck plate, i can always take the deck plate out and go back to a stock gsr block without the deck plate.
hey man i'm taking reasonable offers, the price for this block would below dart's block's price away
Old May 26, 2003 | 07:07 AM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cams &raquo;</TD></TR><TR><TD CLASS="quote">its a golden eagle block, no welding, its a different design than other companys. the reason i didn't want to take it to a shop get it weld it is because i'm scare people might heat up the block too much when they weld it and might mess up the block. and with Golden eagle deck plate, i can always take the deck plate out and go back to a stock gsr block without the deck plate.
hey man i'm taking reasonable offers, the price for this block would below dart's block's price away</TD></TR></TABLE>
That block your selling, do you HAVE to run custom crank and custom rods?!??!~?!
Old May 26, 2003 | 07:29 AM
advanracing62's Avatar
Default Re: Dart Blocks (Jordo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">
That block your selling, do you HAVE to run custom crank and custom rods?!??!~?!</TD></TR></TABLE>
I would imagine at very least you'd have to run a longer stroke crank... What did you have in mind when building the block? It's very "cute" I'd buy it if I had a job, no wife, and could have some fun...
Old May 26, 2003 | 09:27 AM
Dual Cams's Avatar
Jeff at IB already have pistons and rods, all he have to do is order them. the rods would take 2-3 days to get them and the pistons i beleive he already have it in stock.
with the right setup this block should make over 250+.... thats my guess, but jeff said it should make over 270+. so it all depends on the setup.
[bold] but like i said, the pistons and rods, jeff or i can get them no problem and it won't be like months and months wait. i would say your waiting time is only a week[/bold]
Old May 26, 2003 | 09:30 AM
Dual Cams's Avatar
Jeff at IB would take care of the pistons and rods
we already have pistons and rods for this setup, the rods would take about 2-3 days to get them, and i beleive jeff already have pistons for them already.
I beleive with the right setup you'll be making 250+, and jeff believes it should make over 270+... so it all depends on the setup.
[bold] but like i said, the pistons and rods are taken care of, and it won't be like monthes and months wait, it'll be like one week for us to get the pistons and rods [/bold]
Old May 26, 2003 | 12:59 PM
Soon_2b_evil's Avatar
well i got one. cost me 1900 and new rods, pistons, crank, for another 1300 bucks and that gets me 2.0liter actally its a close 1.987 something like that. then a built head that cost some more cash and then a custom turbo kit **** get $$$$$$$.
Old May 26, 2003 | 05:02 PM
lowcivex's Avatar
Default Re: Dart Blocks (Soon_2b_evil)
ive been looking into getting a sleeved block
and some people say they have been having overheating problems with them....
has this happened to anybody
Old May 27, 2003 | 02:11 AM
Dual Cams's Avatar
Default Re: Dart Blocks (lowcivex)
no over heating problems here
ASR_RAMBO
Jul 29, 2005 04:04 PM
preludesi93-arg
Jun 19, 2005 06:44 AM
Aquafina
Nov 2, 2003 05:56 PM
