car won't start!!!!!!! help from all you knowledgeble people.
Old Apr 7, 2003 | 06:42 AM
jr_istheman's Avatar
Default car won't start!!!!!!! help from all you knowledgeble people.
Car problem: I start the car, everything runs fine, RPMs go up to 1500, then drop and I stall out. I tried different settings on the Field controller, and nothing does it. I try giving it some gas and it feels like no gas gets to the engine and the RPMs still drop and I stall out. This problem occurs once a week. The rest of the time, the engine runs like a dream, anyone out there that can help me??? is there something stupid that I should check and it would slove what's going on? just shoot me ideas, I'm tiered of this problem. Thanks!
Old Apr 7, 2003 | 06:43 AM
Default Re: car won't start!!!!!!! help from all you knowledgeble people. (jr_istheman)
engine is a b20/vtec, toda cams, timing set at 0. 12:1 compression
Old Apr 7, 2003 | 06:45 AM
when I push on the gas once the car is started, it boggles and jumps around, the RPMs don't go up constant. I can't pass 4000 RPMs. if I stop giving it gas, it stalls out immidiatly. could it be a bad fuel pump? or my injectors are clogged? could it be the ignition timing? help from anyone would be greatly appriciated!
Old Apr 7, 2003 | 07:21 AM
... anyone???...
Old Apr 7, 2003 | 08:52 AM
GSRfoedoe's Avatar
i think fuel related but it might be the wires on the vtec controller coming loose. give me more updates maybe i can help. good luck
Hylite
Jul 5, 2009 03:47 PM
Mr_Moos
Jul 28, 2007 10:14 PM
Subzonic
Jun 23, 2003 08:16 AM
jr_istheman
Apr 11, 2003 07:42 AM
jr_istheman
Apr 7, 2003 05:58 PM
