car won't start!!! help from all you knowledgeble people.
Old Apr 7, 2003 | 06:08 AM
jr_istheman's Avatar
Default b20/vtec car won't start!!! help from all you knowledgeble people.
Car problem: I start the car, everything runs fine, RPMs go up to 1500, then drop and I stall out. I tried different settings on the Field controller, and nothing does it. I try giving it some gas and it feels like no gas gets to the engine and the RPMs still drop and I stall out. This problem occurs once a week. The rest of the time, the engine runs like a dream, anyone out there that can help me??? is there something stupid that I should check and it would slove what's going on? just shoot me ideas, I'm tiered of this problem. Thanks!
[Modified by jr_istheman, 4:21 PM 4/7/2003]
Old Apr 7, 2003 | 06:10 AM
BryanSprinkel's Avatar
Default Re: car won't start!!! help from all you knowledgeble people. (jr_istheman)
Do you have cams?
Old Apr 7, 2003 | 06:12 AM
engine is a b20/vtec, toda cams, timing set at 0. 12:1 compression.
Old Apr 7, 2003 | 06:22 AM
when I push on the gas once the car is started, it boggles and jumps around, the RPMs don't go up constant. I can't pass 4000 RPMs. if I stop giving it gas, it stalls out immidiatly. help from anyone would be greatly appriciated!
Old Apr 7, 2003 | 06:26 AM
could it be a bad fuel pump? or my injectors are clogged?
Old Apr 7, 2003 | 06:41 AM
anyone??? could it be the ignition timing?
Old Apr 7, 2003 | 07:00 AM
rated_r's Avatar
try changing your fuel filter..... Its cheap could work
Old Apr 7, 2003 | 07:09 AM
Default Re: car won't start!!! help from all you knowledgeble people. (rated_r)
thanks for the good idea. I'll look into the fuel filter. anyone else have this similar problem that could help?
Old Apr 7, 2003 | 07:17 AM
Did you lean it out as much as you can at idle usint the SFC?
Also, you can try adjusting the idle screw on the TB.
Old Apr 7, 2003 | 07:19 AM
Default Re: car won't start!!! help from all you knowledgeble people. (BryanSprinkel)
yeah Brian, I've been playing with the TB all morning and I tried leaning it out, riching it out, everything... blah, I give up, it's time for a visite to Inline Pro. thanks for your help guys.
Old Apr 7, 2003 | 07:21 AM
Give Steve (SGT) a call, see sig for contact info.
G luck.
Old Apr 11, 2003 | 07:42 AM
Default Re: b20/vtec car won't start!!! help from all you knowledgeble people. (jr_istheman)
just to follow up, I had an ignition problem and my fuel pressure was wack. I need a nice s100 system and get dynoed, then I'll be running fine.
Mr_Moos
Jul 28, 2007 10:14 PM
Subzonic
Jun 23, 2003 08:16 AM
jr_istheman
Apr 7, 2003 05:58 PM
jr_istheman
Apr 7, 2003 08:52 AM
