88 and 89-91 crx, are there any diff. in the front struts?
Old Apr 7, 2003 | 05:27 AM
auto-x's Avatar
New User
Default 88 and 89-91 crx, are there any diff. in the front struts?
im ready to order a set of tokico illumina for my 88 crx with 90-93 integra lca. should i get a set for 89-91(front and rear) or a pair of 88 fronts and a pair for 89-91 rears? I appreciate your expert opinion. -rico
Old Apr 7, 2003 | 05:47 AM
JoshDM's Avatar
Default Re: 88 and 89-91 crx, are there any diff. in the front struts? (gude boi)
they do have different part numbers from honda, but they should interchange anyway.
Old Apr 7, 2003 | 06:35 AM
Mr Furball's Avatar
Default Re: 88 and 89-91 crx, are there any diff. in the front struts? (JoshDM)
ok, The 88-89 are the same, As same with the 90-91. Order what ever year you have, if you have 88-89 up front, thats what you order, If you have 90-91 in rear, that's what you order.
88-91 are interchangeable but 88 parts will not work with 91 parts, you have to change everything over to either year. hope this helps. But both will work
Old Apr 7, 2003 | 07:16 AM
auto-x's Avatar
New User
Default Re: 88 and 89-91 crx, are there any diff. in the front struts? (FURBALL B-16)
the second reason i ask this question is it will be cheaper to order a set of front and rears from the same car than 88 fronts and 89-91 crx /93 integra rears. if theres no difference between 88 and 89-91 fronts then i will order the 89-91 front and rears. by the way, the 89-91 crx rear struts will work with 90-93 integra rear lca. thanks again.
Ryan Lantz
Feb 16, 2014 07:25 PM
repingjdm
Nov 5, 2010 01:23 PM
Eee Pee
Nov 1, 2003 10:21 PM
dough-boy
Sep 7, 2003 12:11 PM
ruiner17
May 11, 2003 12:39 AM
