Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
im close to my bumpstops
Old Apr 6, 2003 | 08:14 PM
Lo-Buck EF's Avatar
Default im close to my bumpstops
at my current ride height im about 1/2 inch off the bump stops in the rear and less in the front. i havent cut the bump stops yet but i dont realy think it will help. will it or do i need shoter shox? the car seems to handle well(autox as well as hpde) and doesnt 'seem' to be all over the bumpstops but they have to be hittin them all the time being this low.
tia, spenc
set-up
gc's 400f/300r
tokico illumina 3-4f/5r for autox, 3-4 all way around for daily
Old Apr 6, 2003 | 08:23 PM
Warren's Avatar
Wrong-Way Wang
Default Re: im close to my bumpstops (SOLOef)
I'm almost on my bumpstops, but they are pretty tall, and I'm running an assload more spring rate.
You're all over the bumpstops if they're only 1/2" away.
Warren
Old Apr 6, 2003 | 08:28 PM
Lo-Buck EF's Avatar
Default Re: im close to my bumpstops (Warren)
so should i cut them in half or just let it go?
Old Apr 6, 2003 | 08:30 PM
DB2-R81's Avatar
25 Year Member
Raise the car up or purchase some stiffer springs.
Old Apr 6, 2003 | 08:32 PM
SPiFF's Avatar
The rears should be fine, but you will need to raise your car in the front. With 400# on my DC2, I needed to be a little less then 1 inch up front to stay off the bump stops under normal load. Big bumps (like curbing and T10 at CMP for example) still bottom it out, but that is a non issue.
Old Apr 6, 2003 | 08:36 PM
Lo-Buck EF's Avatar
Default Re: im close to my bumpstops (SPiFF)
i cant realy run stiffer springs on tokicos and i dont have money yet for shorten'd koni. i guess ill have to raise it some. makes sence why a fellow compettor said his car rode like crap. he's lower than i am. hes on the b.s. all the time probably.
thanx
-spenc
Old Apr 6, 2003 | 08:52 PM
illusion's Avatar
there was a trick to check how much room you should have.. i cant find the thread.
you put something around the shock near the top. then you do your autox/hpde run or whatever, and then you check how far up the thing went. damn i suck at explaining.
Old Apr 6, 2003 | 09:04 PM
buji's Avatar
New User
Default Re: im close to my bumpstops (illusion)
I think the word you're looking for is 'ziptie.'
Old Apr 6, 2003 | 09:20 PM
illusion's Avatar
Default Re: im close to my bumpstops (buji)
Old Apr 7, 2003 | 03:10 AM
Lo-Buck EF's Avatar
yea, i remember that thread. the problem isnt that im not sure if im hittin the bumpstops. i know i am. my question is should i cut them or raise the car.
-spenc
Old Apr 7, 2003 | 04:12 AM
solo-x's Avatar
call ground control. they have a $75 solution to your problem.
nate
Old Apr 7, 2003 | 04:35 AM
Lo-Buck EF's Avatar
Default Re: im close to my bumpstops (solo-x)
nate
dont say stiffer springs either
Old Apr 7, 2003 | 05:20 AM
SPiFF's Avatar
I have not noticed much difference, other then the pimpy look and that I can't use my strut tower bar anymore.
Old Apr 7, 2003 | 05:22 AM
.RJ's Avatar
.RJ
were you able to get more suspension travel with them?
RJ - who has two sets in his kar
Old Apr 7, 2003 | 05:39 AM
Lo-Buck EF's Avatar
-spenc...still in the dark about this 75 dollar fix but i think it has something to so with relocating the shock mointing
[Modified by SOLOef, 9:43 AM 4/7/2003]
Old Apr 7, 2003 | 05:40 AM
Todd00's Avatar
I said I don't want a title!
Just cut the first notch off of them, but don't do anything like remove them completely--they are there for a reason.
And yeah, you might need to raise the car. Unless you have suspension specifically designed for the car being slammed (which an OTS koni/GC setup is not), you'll run into problems.
Old Apr 7, 2003 | 05:44 AM
SPiFF's Avatar
RJ, I had about 1 inch of travel on my old car. Stock mounts, OE bump stop cut in half, and A-Arm swap. When I put my setup on the new car, using the GC mounts, I didn't change the location of the spring perch or the snap ring. Only difference is I don't have the upper A-Arms swaped yet. I had less then 1/2 inch. I cut off about 1/3 of the new bump stop and I should be back to where I was. Donno.
[Modified by SPiFF, 9:49 AM 4/7/2003]
Old Apr 7, 2003 | 05:48 AM
91SiKen's Avatar
http://www.ground-control.com/gchoncatnew.htm
Here is your $75 solution. (For those that haven't seen GC's writeup) Still waiting to hear some more feedback on this product before ordering mine. Let us know guys
:edited: last post was created while I was writing mine.
[Modified by 91SiKen, 3:08 PM 4/7/2003]
Old Apr 7, 2003 | 05:55 AM
Lo-Buck EF's Avatar
Default Re: im close to my bumpstops (91SiKen)
OMFG, thats exactly what i was thinking and should totally work. are they STS legal or would they not be considerd "suspension must attach to stock mounting points?"
-spenc
Old Apr 7, 2003 | 06:02 AM
Todd00's Avatar
-spenc
Looks like protest fodder to me. I'd get a definite ruling from the national office before I blew the cash on them.
Old Apr 7, 2003 | 06:05 AM
carl_aka_carlos's Avatar
i don't see why they wouldn't be STS legal? the whole assembly still bolts to the unibody in the same place right?
Old Apr 7, 2003 | 06:06 AM
SPiFF's Avatar
Default Re: im close to my bumpstops (carl_aka_carlos)
If you can run JIC, etc JDM dampers which have theor own upper mounts, you can run these.
Old Apr 7, 2003 | 06:07 AM
essex's Avatar
play with your forks
https://honda-tech.com/zerothread?id=378981
look near the bottom of the thread
[Modified by essex, 3:08 PM 4/7/2003]
Old Apr 7, 2003 | 06:25 AM
Lo-Buck EF's Avatar
Default Re: im close to my bumpstops (essex)
interesting. i have to look at my shox. i know when i put them in i droped the shock all they way intot he fork as far as it could go. i have to look to see if i can trim something back to get travel. are there any other forks that are shorter than 89-91 civic forks?(although that would only help the front )
-spenc...who is reeaming of all kinds of goodies to fix this travel problem
Old Apr 7, 2003 | 06:29 AM
essex's Avatar
rear EF shocks have a **** load of travel
If you ever want to see your travel as its hard to look at with the wheel there, put a small spare tire on there and you can see how much travel you have + any spring rates above 600 for sure will keep the rear off the bumstops.
