You guys with 92-2001 Integra Helm manual...
Banned
From: at last finally back to sweet home, sunny north cali, usa
Hey guys, I'm performing an independent cam test (CTR, JUN 3, Toda B, Spoon, Skunk2) and I'm also collecting all the valve train info I can. If you have 93-2001 Helm Integra manual please look these up and post.
92-93 GSR spec (should be same as delsol's)
94-2001 GSR spec (I suspect these should be the same through the years)
98, 2000, 2001 ITR spec
In the Specifications chapter (probably chapter 3), under Cylinder Head/Valve Train there is a camshaft spec. These are for 95 del Sol B16A.
Cam lobe height
intake primary 33.088 (1.3027)
mid 36.267 (1.4278)
secondary 34.978 (1.3771)
exhaust primary 32.785 (1.2907)
mid 35.720 (1.4063)
secondary 34.691 (1.3658)
Also Valve Seat "stem installed height"
intake 37.465-37.935 (1.4750-1.4935)
exhaust 37.165-37.635 (1.4632-1.4817)
Cam lobe height
mid 36.267 (1.4278)
mid 35.720 (1.4063)
I'll get the ball rolling....
1994-1998 GSR Helms Manual
IN
Primary 33.411 mm (1.3154 in.)
Mid 36.377 mm (1.4322 in.)
Secondary 34.547 mm (1.3601 in.)
EX
Primary 33.111 mm ( 1.3036 in.)
Mid 35.720 mm (1.4063 in.)
Secondary 34.381 mm (1.3536 in.)
Valve Guide Installed Height IN and EX 12.55-13.05 mm ( 0.494-0.514 in.)
cheers
PS I emailed you awhile back on this info for the ITR primary and secondary lobe heights at g-speed and I guess you never replied because you don't have them either!!
IN
EX
cheers
'98, specifications taken from Acura Integra 1998 Service Manual
Cam lobe height
mid 36.865 (1.4138)
secondary 34.732 (1.3674)
mid 36.333 (1.4304)
'00, specifications taken from Acura Integra 2000 Service Manual Supplement
Cam lobe height
mid 36.865 (1.4138)
mid 36.333 (1.4304)
I hope that these help.
Austin
[Modified by 00itr0757, 1:34 AM 6/23/2001]
Cam lobe height
mid 36.865 (1.4138)
mid 36.333 (1.4304)
Cam lobe height
mid 36.865 (1.4138)
mid 36.333 (1.4304)
Austin
Banned
Banned
Thanks Tuan. The lower lob specs @ 1 mm is in the HyperRev mags, which I can't find mine lately, otherwise I'd replied... sorry.
Need the valve stem install height (which is the spring install height), not the valve guides. Thanks.
Austin
