front lower ball joint installation and removal
Guest
Posts: n/a
When i accelerate, my front wheels will move backwards in the wheel wells. when i reverse, they will move forwards. im asuming my lower ball joints are completely toast. aparently they are suposed to have 0.5mm of play. i can twist and turn mine all over the place.
these have to be pressed in and pressed out im assuming. can you press them out with a jack? press them back in with a c-clamp? or do you have to pull the knucle completely off and throw the bad boys in a vise or what?
In my case I took both knuckles off, it is easier that way. I thought that they were gonna have to be pressed out. I figured I'd try to hit them out with a hammer. I just threaded the nut back onto the joint and gave it 5-6 hard whacks and they pop right out. Then again I don't have rust issues. Try it. Put the new ones in and give em a few taps to seat them.
fyi, a 5lb sledge was the weapon of choice.
Guest
Posts: n/a
Make sure to buy another EF when the insurance check rolls through...if your getting one.
Look on the bright side.... you'll have nice new ball joints for your next civic.
seriously, sorry to hear about that and glad to see you're still alive and aparently OK.
Guest
Posts: n/a
yeah im fine. i have no injuries from this accident. i was having S4 flashbacks right before i hit tho which sucked.
my accident yesterday was nothing compared to that on in Nov tho
quite lucky.
quite lucky.
quite lucky.
quite lucky.
that accident i was a passenger in, in nov. that was my friends car. crashed @ aprox 140mph
saw it...believe it, it doesnt even look like the s4 it used to be. goodluck al
on a good not i am picking up a 91 si for parts this weekend probably so if you need anything im me
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peichie »</TD></TR><TR><TD CLASS="quote">saw it...believe it, it doesnt even look like the s4 it used to be. goodluck al
yeah i was thinking about swaping my harnesses over however i dunno how well that will work. hell i might as well i have the tear the entire car aparent anyway
</TD></TR></TABLE>yeah i was thinking about swaping my harnesses over however i dunno how well that will work. hell i might as well i have the tear the entire car aparent anyway
PatrickGSR94
Suspension & Brakes
18
May 12, 2010 09:55 AM
no other way around that eh?
Hope insurance does you well.
