could someone post the helms ecu pinout?
pretty much what the topic says. could someone please post the ecu pinout from the helms manual?
oh yeah, the ecu is from a 95 civci ex. it's a p28 i believe.
[Modified by serious, 10:14 PM 4/6/2003]
http://tech2.hybridgarage.com/ecu.php?ecutype=p72_obd1
OBD-1 (p72 and p30 pinouts, not sure if its the same for p28)
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A4 GRN/YEL VTS VTEC solenoid
A5 BLU INJ3 INJ3
A6 ORN/BLK PO2SHTC O2 sensor (heating element)
A7 GRN/BLU FLR1 fuel pump
A8 (empty)
A9 BLK/BLU IACV IAC valve
A10 (empty)
A11 (empty)
A12 GRN FANC engine coolant temp switch
A13 GRN/ORN MIL MIL (check engine light)
A14 (empty)
A15 BLK/RED ACC (a/c compressor clutch)
A16 WHT/GRN ALT C alternator
A17 PNK/BLU IAB IAB Solenoid
A18 (empty)
A19 YEL (AUTO ONLY) (a/t trans only)
A20 RED PCS EVAP purge control solenoid
A21 YEL/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
A25 YEL/BLK IGP2 to main relay and to gound for o
A26 BRN/BLK LG1 gound
B1 YEL/BLK IGP2 to pin A25
B2 BRN/BLK LG2 ground to shields for CYP & TDC
B3 (a/t trans only)
B4 (a/t trans only)
B5 BLU/RED ACS a/c switch
B6 (empty)
B7 (a/t trans only)
B8 GRN PSPSW PSP switch
B9 BLU/WHT STARTER SIGNAL starter signal
B10 ORN VSS vehicle speed sensor
B11 ORN CYP P CYP -P
B12 WHT CYP M CYP -M
B13 ORN/BLU TDC P TDC -P
B14 WHT/BLU TDC M TDC -M
B15 BLU/GRN CKP P CKP -P
B16 BLU/YEL CKP M CKP -M
D1 WHT/BLU VBU Back Up Power
D2 GRN/WHT BKSW brake switch
D3 KS Knock Sensor
D4 BRN/WHT SCS service check connector
D5 (empty)
D6 BLU/BLK VTM VTEC pressure switch
D7 LT BLU TXD/RXD (data link connector)
D8 (empty)
D9 WHT/RED ALT F alternator
D10 GRN/RED ELD electric load detector
D11 RED/BLK TPS TPS Signal
D12 YEL/GRN
D13 RED/WHT ECT ECT sensor
D14 WHT/RED PHO2S O2 sensor
D15 RED/YEL IAT IAT sensor
D16 WHT/BLK VREF VREF
D17 WHT/YEL MAP Map Signal
D18 (a/t trans only)
D19 YEL/WHT VCC1 MAP 5V
D20 YEL/BLU VCC2 TPS 5V
D21 GRN/WHT SG1 MAP GND
D22 GRN/BLU SG2 TPS GND
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A5 BLU INJ3 INJ3
A8 (empty)
A10 (empty)
A11 (empty)
A14 (empty)
A18 (empty)
A21 YEL/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
B3 (a/t trans only)
B4 (a/t trans only)
B6 (empty)
B7 (a/t trans only)
D3 KS Knock Sensor
D5 (empty)
D8 (empty)
D12 YEL/GRN
