My gears won't go in easily. Would replacing tranny fluid fix the problem?
My gears don't click in as it use to. It's a little bit harder to put it into gear. Would replacing tranny fluid fix the problem? How often should you replace the tranny fluid?
if your car has hydraulic (sp?) clutch bleed it
sometimes if there is air in there your clutch wont disengage all the way and gears will be harder to grab
and i thought it was 30,000 anyone know what it says in the manual?
viva60
Feb 19, 2006 12:43 PM
