Installing the VAFC on my 1998 ITR , where can if find the best step by step instructions
Please help, because the manual is NOT very clear. Please also explain the initialising set up.
Thank you guys
Douglas
Thank you guys
Douglas
Yes I printed all the pages from the website , but its quit confusing. Wich of the conections on the ECU is the right one , does any one knows the correct conector locations for all the conections to be made on a 1998 ITR and the correct initialising setup for a 5.600 rpm VTEC point ?
Thnaks
Thnaks
Well I have a 00' si. I installed my own apexi controller and I beleive the si and R share the same wiring. So Here is a link to all the wire you will need. http://jdmfan.com/index.php?information=ecm-pcm_99-00
I would check all the wire just to make sure but I think they are the same. Hope this helps
if the apex-i directions aren't step by step enough for you then you shouldn't be attempting this kind of difficult install.
for ITR797 from Orlando , did you install aVAFC on your car ?
I am looking for people that can share their experiance on an 1998 ITR , because I have two different wiring diagrans from the APEXI website.
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
http://www.bseries.net/ helped me out a lot
