braking=shaking like hell!
Old Apr 6, 2003 | 10:20 AM
JSPECHB's Avatar
Default braking=shaking like hell!
when i break my car shakes like hell! i was thinking the alignment is bad? any suggestions? the car is lowered, i got a 91 hatch. it did it a little when i got the car, i put 17's on, it still did it alittle. yesterday i put my stocks back on and when i brake it shakes like a ****!
Old Apr 6, 2003 | 10:42 AM
Blaze45's Avatar
Brrraaaap!
Default Re: braking=shaking like hell! (JSPECHB)
Sounds like you have warped rotors. replace those and get an alinment and that sould fix it.
Blaze
Old Apr 6, 2003 | 10:46 AM
hybridmoose's Avatar
Default Re: braking=shaking like hell! (Blaze45)
yup could be the rotors. when you replace them make sure you use a hand torque wrench to properly torque them or you could warp them by overtorqueing. I did that on my hf when i used an air wrench to put my wheels on.
Old Apr 6, 2003 | 10:48 AM
Lil Red CRXsi's Avatar
If the car only shakes while braking--get the rotors turned.They do tend to warp easy on Hondas.As for the alignment-you should get it done to save your tires,but if the car shakes a little say around 50 or so-try balancing the tires again.
Old Apr 6, 2003 | 10:50 AM
JSPECHB's Avatar
Default Re: braking=shaking like hell! (Lil Red CRXsi)
thanks for the feedback! rotors are like $30 arent they? i might as well get all new brakes while im at it.
Old Apr 6, 2003 | 12:00 PM
Blaze45's Avatar
Brrraaaap!
Brakes are so easy to do on hondas. takes me 20 min to do both sides rotors and pads.
good luck
Blaze
Old Apr 6, 2003 | 12:31 PM
importfan85's Avatar
Brembo blanks (the ones to get) are like $18 a piece at http://www.nopi.com
Old Apr 6, 2003 | 02:03 PM
d357r0y's Avatar
You may also want to check the caliper pivot bolt (the top one). My brakes were shaking like crazy. I replaced the rotors thinking it was a warped one and while I was doing the job I noticed the pivot bolt was loose. I tightened it up and returned the rotors and the job ended up being free and there was no more crazy brake shake.
just a suggestion.
Old Apr 6, 2003 | 04:17 PM
Ef Whore's Avatar
Default Re: braking=shaking like hell! (d357r0y)
Yeah shaking brakes are annoying---Mine start up about every 3 or so months. I just pull em and cut em and thats it--but break them in the right way so they seat properly.
MUGEN_EG95
Honda Civic (2006 - 2015)
13
Apr 20, 2008 10:15 PM
The Epidemic
25
Sep 3, 2007 04:24 AM
poppypizza
Apr 18, 2007 08:52 PM
SuShiBoiiii
Aug 21, 2003 07:45 PM
6ghatch
May 8, 2002 06:53 PM
