what type of header r u guys runnin w/ b16a
Old Apr 6, 2003 | 07:27 AM
1stealthls's Avatar
Default what type of header r u guys runnin w/ b16a
just want to know what i can use i want 4-1 but dont know if it will clear the crossmember
Old Apr 6, 2003 | 08:08 AM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: what type of header r u guys runnin w/ b16a (1stealthls)
I don't think any header will clear the crossmember. I'm putting a DC 4-2-1 header in this week and I'm sure it will need some cutom fitting. The 4-1 header hangs even lower so you will mos def need some modification to the cross member to make it fit.
Old Apr 6, 2003 | 08:31 AM
90civichbsi's Avatar
Default Re: what type of header r u guys runnin w/ b16a (SeaBass)
im using a Greddy 4-2-1 and i have about a centimeter clearance
Old Apr 6, 2003 | 11:12 AM
Sq_91Si's Avatar
I'm running a JDM DC 4-1. I had to cut the member and it hangs too dam low. I welded a 1/4'' plate to the bottom of my header to keep from crushing it! With that tight to the header it's 2'' from the ground.
dx_rex
Jan 9, 2009 07:24 AM
tempsohc
Nov 18, 2007 10:01 AM
germanEE8
Nov 20, 2003 11:19 PM
CRX_VTEC
Jul 28, 2001 06:11 PM
