Weird whinning noise in all gears on acceleration only, please help
Old Apr 6, 2003 | 06:51 AM
sirminder's Avatar
Default Weird whinning noise in all gears on acceleration only, please help
Suddenly a weird kinda whinning noise creeped up on me. This happens in all gears (1-5) under regular to semi-aggressive acceleration. But if i drive in a moderate way and ease the acceleration to shift at 3k or so, i dont hear it. When Im on the highway (or sreet) cruising at 70mph (or 35-40) i dont hear it. But if i want to increase speed and step on the pedal kinda hard (not full throttle), I hear the noise for a few seconds and then it goes away. But if I easily step on the gas I dont really hear it. Im not sure if any of you can understand me. I wish i can take some of you for a test drive as this is driving me up the wall. I even took local mechanic for a drive and he said the same problem is on his accord but cant figure it out. He said that it could be the air filter or intake. I cleaned the air filter and put my oem air intake back in and the problem is still there. Again, I dont hear the noise when the speed is constant. But if i increase speed, then i hear it for a few seconds and it goes away.
Old Apr 6, 2003 | 11:06 AM
omahaturbocivic's Avatar
Default Re: Weird whinning noise in all gears on acceleration only, please help (sirminder)
Mine did that too, it was the input shaft bearings in the tranny. When we pulled the tranny you could feel a lot of play in the input shaft. Bad countershaft bearings will do the same thing as well. I was not sure at first what it was either but after driving on it hard for like 3 weeks it started popping out of 2nd and 5th gear if you did not hold the shifter in gear while deaccelerating. If I were you I would start shopping for a new tranny.
[Modified by omahaturbocivic, 2:07 PM 4/6/2003]
Old Apr 6, 2003 | 03:48 PM
sirminder's Avatar
Default Re: Weird whinning noise in all gears on acceleration only, please help (omahaturbocivic)
new tranny? no!!!! well i guess that will be my change to get an lsd
Old Apr 6, 2003 | 03:50 PM
sirminder's Avatar
anyone else with uplifting suggestions?
Old Apr 6, 2003 | 04:04 PM
3rdGteg's Avatar
what he said above.....one of the bearings in the tranny. Open her up and check/replace bearings.
Canadian_EF
Jun 9, 2009 11:16 AM
victor.m
Mar 9, 2009 09:40 AM
DBeight
Jul 15, 2008 08:15 AM
jr408
Mar 19, 2008 09:18 AM
crazy4carz
Aug 28, 2007 05:29 PM
