carsound cat for for integra
Old Apr 6, 2003 | 04:58 AM
JunIntegra's Avatar
Default carsound cat for for integra
has anyone done the 2.5 header with carsound cat?? is it direct bolt in? and does it come with flanges and gaskets?"?
[Modified by JunIntegra, 1:58 PM 4/6/2003]
Old Apr 6, 2003 | 07:35 AM
Rory Breaker's Avatar
Default Re: carsound cat for for integra (JunIntegra)
You need to get the cat custom made...it comes from Carsound as a blank cat. No 02 bungs & no flanges. An exhaust shop can weld on the flanges and bung(s) and slice the cat as necessary to fit your application.
Old Apr 6, 2003 | 09:01 AM
Padawan's Avatar
Darth ModerVader
If you order a universal Carsound cat., then no. If you order one that has been custom made for your application, then yes .
EDIT: To avoid confusion, I should mention that the "custom-made" cats. which I refer to start out as universal Carsounds, but are assembled to the correct length and with the correct flanges, bungs, etc.for each application These are not available from Carsound, but instead can be purchased from companies such as SMSP and IPS Racing.
[Modified by Padawan, 1:13 PM 4/6/2003]
Old Apr 6, 2003 | 11:50 AM
daLixz25's Avatar
I'm assuming you'd have to specify your application upon ordering the custom cat? I'm planning on replacing my cat when I get my DC JDM 4-1 and I don't know exactly what the scenario is gonna be like, especially since I have the extension piping on my ITR exhaust for my 96 GSR.
Does anyone have a similar setup...just in order for me to know what needs to be done for the install?
[Modified by daLixz25, 12:50 PM 4/6/2003]
Old Apr 6, 2003 | 11:55 AM
Padawan's Avatar
Darth ModerVader
Default Re: carsound cat for for integra (daLixz25)
You'll just need to run the standard GS-R (94-99) version of the Carsound for JDM-spec. headers. As far as the install, everything will bolt-up.
Old Apr 6, 2003 | 12:20 PM
JunIntegra's Avatar
Default Re: carsound cat for for integra (Padawan)
awesome thanx guys!1
loner714
Jan 19, 2007 08:32 PM
shhh151
Aug 4, 2004 02:32 PM
1998teg
Jul 29, 2004 11:29 AM
KamikazeSol
Feb 21, 2004 02:25 PM
