Half Rad for CRX who makes it???
you can just use the 92-00 civic radiator. From what I know, its a little taller, so you have to lean it back just a little. My buddies used the fluidyne 92-00 radiator in his crx and it works perfect
The company is called C&R and it was in the Modified Magazine for the month of March. I was just wondering if anyone has this rad in there car????? Pics???? I know I can use the 92-95 Civic rad but this rad is a bolt in and requires no mods..
[Modified by JDMCRX, 5:55 AM 4/7/2003]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">The company is called C&R and it was in the Modified Magazine for the month of March. I was just wondering if anyone has this rad in there car????? Pics???? I know I can use the 92-95 Civic rad but this rad is a bolt in and requires no mods..
[Modified by JDMCRX, 5:55 AM 4/7/2003]</TD></TR></TABLE>
I just bought the C&R radiator for the 92 civic for my crx. its not installed yet but will be soon
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_Fan »</TD></TR><TR><TD CLASS="quote">
I just bought the C&R radiator for the 92 civic for my crx. its not installed yet but will be soon</TD></TR></TABLE>
did it come with a fan and how much was it?
mines on order (the C&R 88-91 civic/crx half size that mounts in stock locations) ill take pics after i put it in.
EDIT: to answer the original question - the company is C&R.. but good luck trying to get one unless someone has them in stock because Rob from C&R LAGS.
PWR also makes one that is the same size as the 92-95 radiator but is sideways.so it clears without having to tilt it back.call them and ask for colin and say you are looking for the civic radiator that is a 92-95 dimension.if you have problems IM me and ill holla at ya.hopefully my picture works
I have a 92-95 radiator in my car, all I did was notch the crossmember with my cutoff tool and weld in some custom brackets the radiator sits straight and has no clearance issues, It was pretty simple and quick I would say it only took me and hour to do the entire install. I will try to get some pics up
Sanj
Oct 14, 2005 06:52 PM
b18-c-rx
16
Jan 17, 2005 11:40 AM
Vera
26
May 3, 2004 06:37 AM
