i f*cking hate my car
Old Apr 5, 2003 | 10:27 PM
wu tang's Avatar
Default i f*cking hate my car
ok...first off, my car i the biggest piece of ****, it also has never ending problems. so heres my new problem. i have code 4. its the crank sensor. i know its in my dizzy, so i pulled it out and put in a ls dizzy. and i still have a code 4 and it runs like **** and on both dizzy's it wont rev past 3. also i have a b16 in it and i had to do the dpfi to mpfi. and i allready checked my wires and such. can someone help me out.
Old Apr 5, 2003 | 10:30 PM
91_hatch_si's Avatar
Default Re: i f*cking hate my car (wu tang)
ill buy ur car $300 cash
Old Apr 5, 2003 | 10:33 PM
wu tang's Avatar
Default Re: i f*cking hate my car (91_hatch_si)
uhhhh..........no, im not that destperate
Old Apr 5, 2003 | 10:48 PM
USDM 4G VTEC's Avatar
if u change dizzy and problem still there make sure that u wired the dizzy the right way.... go back n recheck all connections of ur dizzy 2 the ecu
Old Apr 5, 2003 | 10:52 PM
wu tang's Avatar
Default Re: i f*cking hate my car (USDM 4G VTEC)
well...i just got done checking, eveything is in the right order, also my connections are not soldered. they are twisted are wraped by heat shrink. the weird part is, today my car was running great but sometimes it would throw the code 4 and now its stuck on code 4.
Old Apr 5, 2003 | 11:17 PM
SEA Hag's Avatar
You probably should look into soldering your connections once you get the wires right. It is not that hard, and you dont want your ecu connections randomly disconnecting themselves which always happens with twisted/butt connectors.
Old Apr 5, 2003 | 11:55 PM
Louie B.'s Avatar
definately solder all of the conections
Old Apr 6, 2003 | 12:24 AM
EF Two's Avatar
Default Re: i f*cking hate my car (thumpu77)
I had the same problem. But I found out the bolts that hold the distributor to the head worked themselfs loose. Tightened them up and haven't had the code 4 since. I hope it doesn't come back. Sucks when you can't rev past 4000rpm
Old Apr 6, 2003 | 12:05 PM
wu tang's Avatar
Default Re: i f*cking hate my car (DX_Tuner)
ok...i'll try that in a few minutes, but the weird par is, on my b16 ecu i have a code 4 and 14. and on the hf ecu i have a code 20. and the car runs great. now wtf is going on? also, when u do a mpfi witch plug should go on the iac valve? the green plug?
Old Apr 6, 2003 | 12:20 PM
wu tang's Avatar
ok..code 14 is now gone, its just stuck on 4
Old Apr 6, 2003 | 12:22 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
when you have never ending problems with a car, just get rid of it. That is what I did and I am happy that I did. No more money out of the pocket for parts....good luck on fixing your car, keep us posted. So if I ever decide to get a b16 and I have the same problem then i will know what to do.
Old Apr 6, 2003 | 12:27 PM
wu tang's Avatar
Default Re: i f*cking hate my car (dgonzals)
lol, thanks man, but the thing that pisses me off, was that for the first time, it was runing soooooo good.and now this 1 dam code thing thats throwing everything off.
Old Apr 6, 2003 | 05:30 PM
civbeater90's Avatar
yeah green plug goes to iacv
Old Apr 6, 2003 | 05:33 PM
civicmark's Avatar
do it
Old Apr 6, 2003 | 05:47 PM
Buzz Kill's Avatar
Default Re: i f*cking hate my car (civicmark)
I was throwing a code 6 that wouldn't go away.
I had the two plugs twisted around each other prior to being plugged in and the wires were being pulled.
I untwisted the plugs and the problem went away.
Old Apr 6, 2003 | 05:48 PM
E-AT_me's Avatar
hey now.. don't use such words as hate.. and no f-bombs here..
anyway.. take your time.. get yourself a helms manual and go through the steps...
i hate to say this, but i didn't have a single problem when i dropped my b16a in.. i may be the only one..
Old Apr 6, 2003 | 07:18 PM
wu tang's Avatar
Default Re: i f*cking hate my car (Rexman)
well rexman, i think i can use the word hate, why? case my carhasnt ran right since august last year. and buzz, im gonna see if i have ay twisted ire, they are all soldered now to
monster d
Jun 12, 2013 10:20 PM
builtsinglecam
Nov 15, 2009 02:05 AM
crxpwr1
18
Apr 3, 2007 11:21 AM
boosted k20
Jul 27, 2005 07:14 AM
ludelvr
Jul 15, 2004 10:29 AM
