top speed 90 accord LX
Old Apr 5, 2003 | 09:51 PM
madskillz's Avatar
Default top speed 90 accord LX
Is it limited 112? and if any of you rechipped your ecus, what's yours top out at?
thanks
Old Apr 5, 2003 | 11:28 PM
IwanAturBo's Avatar
Default Re: top speed 90 accord LX (madskillz)
mine goes to the max... stock ecu se 91
Old Apr 6, 2003 | 09:10 AM
twkdCD595's Avatar
Default Re: top speed 90 accord LX (IwanAturBo)
only some of the overseas and canadain cars have the speed limiter.
all us models usually are power/ drag limited to about 130 ISH (not positive of exact number as it varies and the speedo is not even certified which means it could be slightly inaccurate at speeds that high.)
Old Apr 6, 2003 | 10:04 AM
Superdragr45's Avatar
Default Re: top speed 90 accord LX (twkdCD595)
what about the ex?? mine has I/H/E and it topped out at 125 mph. is there a difference in the cu and limiter or are they (the ecu's) all the same??
Old Apr 6, 2003 | 02:06 PM
professorman's Avatar
Default Re: top speed 90 accord LX (Superdragr45)
i think they say ex's are heavier, hence the power increase is not sufficient to pull the increased weight over the lx....that's for the 94....not sure what it is for the 90
Old Apr 7, 2003 | 09:42 AM
SearchBeforeUPost!'s Avatar
Default Re: top speed 90 accord LX (profroopchan)
what are the best aero enhancements to increase the drag-limited top speed?
Old Apr 7, 2003 | 09:55 AM
kasper's Avatar
I've had my 90 EX bottomed out w/ intake at 130, it may be off but thats what the speedometer said
Old Apr 7, 2003 | 03:33 PM
urbanlegend21's Avatar
New User
Default Re: top speed 90 accord LX (kasper)
whyy do you want to know?
Old Apr 7, 2003 | 05:32 PM
k-mart's Avatar
Default Re: top speed 90 accord LX (urbanlegend21)
my 91 lx topped out at approximately 122 and a buddy of mine in a 93 lx did the same. we both had exhaust and intake at the time...if that helps out any
[Modified by k-mart, 2:33 AM 4/8/2003]
Old Apr 7, 2003 | 08:10 PM
Showoff's Avatar
Default Re: top speed 90 accord LX (k-mart)
top speed dotn go by mods that you did or doing to your car is all in ECU's so if u wanna go fatster rechip it or get diffrent ecu i have a JDM P13 H22A and i top out at 116 MPH sux when u have one more gear to go and its at VTEC point of engagment
009edgar
Feb 28, 2007 10:27 PM
cbamishere
Feb 15, 2003 11:36 AM
rich
Mar 26, 2002 06:04 PM
