California drivers: front license plate
Old Apr 5, 2003 | 09:12 PM
kotetu's Avatar
Default California drivers: front license plate
I'm sure everyone in CA. knows that you are required to attach the front license plate.
I'm curious if anyone has been ticketed for not having it, and also curious if anyone has tried displaying it in the front window on the dash.
The CVC says it must be attached not more than 60 inches above the ground. That's 5 feet, so the dash would be more than within limits.
Anyone have any stories etc to share?
Old Apr 5, 2003 | 09:15 PM
iam7head's Avatar
Default Re: California drivers: front license plate (kotetu)
both plates required, front plate must be mounted at the center of the bumper(except side mount plate from factory) or else phat big ticket
[Modified by iam7head, 6:36 AM 4/6/2003]
Old Apr 5, 2003 | 09:54 PM
eh3 93's Avatar
Default Re: California drivers: front license plate (iam7head)
If you get caught its a fix-it ticket. Put it back on, have it signed off by a cop and pay $10.
Old Apr 5, 2003 | 10:09 PM
eujin's Avatar
Default Re: California drivers: front license plate (eh3 93)
that stupid **** happened to me in SF. got ticketed for not havin front plate "attached" to front bumper. i had the plate on my dash board for months. and no cop said anything till that time. pissed me off and wasted my time. i had the BW front fascia at the time there was no place to put it....lol ********. i hav a diff front end and now my plate sits behind the grill. not visible at night time unless someones headlights are flashed at it. i better not get a ticket for that , lol.
Old Apr 5, 2003 | 10:16 PM
Al Bundy's Avatar
Just put eh plate in the front. IMO....it doesn't look bad at all
Old Apr 5, 2003 | 11:16 PM
Dr. EKology's Avatar
Wrong! You can get ticketed for not having a front plate WHILE PARKED, which really sucks ***! Its about $35 i believe, one of my friends got burned for this.
Old Apr 5, 2003 | 11:30 PM
NrG's Avatar
NrG
Default Re: California drivers: front license plate (EKology)
putting plates on the dash is bad..
i've seen pictures, and heard storys of people's head getting chopped off by it..
if you get into a car acident, the metal liceans plate can fly into your head, and cause serious injury.
just follow the law and stop trying to look cool
Old Apr 6, 2003 | 12:01 AM
built562's Avatar
Default Re: California drivers: front license plate (NrG)
Here are some of my ecounters with the police, it has to been physically attached to the front of the car, ie screws and not velcro or zip ties. It used to be a $10 fix it but now its a bigger ticket and now even parking enforcement can give your parked car a ticket for no front plate and expired tags (unless the car is parked inside your driveway or garage) but if its on the street watch out.
I have also heard of people being injured because of flying plates from the dash in an accident and those stupid chrome fire extinguishers on the a pillar flying off and hitting people, so put it on.
Old Apr 6, 2003 | 12:07 AM
locass316's Avatar
Default Re: California drivers: front license plate (akumaracer)
Its just a fix it ticket (10 dollars) but I hear if you get caught the second time around it cost more. I think its better to not have it on the dash if your going to do so because it draws more attention to cops when they see it on the dash instead of just not having it at all. I just drove around without it and when you get pulled over just say you just got your bumper repainted and havent got home to put it back on yet. IF that dont work then **** it just take the ticket.
Old Apr 6, 2003 | 01:00 AM
nek0's Avatar
Don't you guys read your RCW's??? This is almost same as the state of Washington and doesn't say anywhere the plate has to be installed on the bumper. My friend got away with so many front license plate ticket because he has them installed about five inches above the dashboard.
CALIFORNIA CODES
VEHICLE CODE
SECTION 5200-5206
5200. When two license plates are issued by the department for a
vehicle, they shall be attached to the vehicle for which they were
issued, one in the front and the other in the rear. When one license
plate is issued for use upon a vehicle, it shall be attached to the
rear thereof.
5201. License plates shall at all times be securely fastened to the
vehicle for which they are issued so as to prevent the plates from
swinging and shall be mounted in a position to be clearly visible,
and shall be maintained in a condition so as to be clearly legible.
The rear license plate shall be mounted not less than 12 inches nor
more than 60 inches from the ground, and the front license plate
shall be mounted not more than 60 inches from the ground, except as
follows:
(a) The rear license plate on a tow truck may be mounted on the
left-hand side of the mast assembly at the rear of the cab of the
vehicle, not less than 12 inches nor more than 90 inches from the
ground.
(b) The rear license plate on a tank vehicle hauling hazardous
waste, as defined in Section 25117 of the Health and Safety Code, or
asphalt material may be mounted not less than 12 inches nor more than
90 inches from the ground.
(c) The rear license plate on a truck tractor may be mounted at
the rear of the cab of the vehicle, not less than 12 inches nor more
than 90 inches from the ground.
(d) The rear license plate of a vehicle designed by the
manufacturer for the collection and transportation of garbage,
rubbish, or refuse and which is used regularly for the collection and
transportation of that material by any person or governmental entity
employed to collect, transport, and dispose of garbage, rubbish, or
refuse may be mounted not less than 12 inches nor more than 90 inches
from the ground.
(e) No covering shall be used on license plates except as follows:
(1) The installation of a cover over a lawfully parked vehicle to
protect it from the weather and the elements does not constitute a
violation of this subdivision. Any peace officer or other regularly
salaried employee of a public agency designated to enforce laws,
including local ordinances, relating to the parking of vehicles may
temporarily remove so much of the cover as is necessary to inspect
any license plate, tab, or indicia of registration on a vehicle.
(2) The installation of a license plate security cover is not a
violation of this subdivision if the device does not obstruct or
impair the recognition of the license plate information, including,
but not limited to, the issuing state, license plate number, and
registration tabs, and the cover is limited to the area directly over
the top of the registration tabs. No portion of a license plate
security cover shall rest over the license plate number.
(f) No casing, shield, frame, border, or other device that
obstructs or impairs the reading or recognition of a license plate by
a remote emission sensing device, as specified in Sections 44081 and
44081.6 of the Health and Safety Code, shall be installed on, or
affixed to, a vehicle.
Carry them with you...that's what I do. When I asked the judge about the front license plate he didn't say it's illegal but mentioned some cops may hassle about it and give me a ticket.
Old Apr 6, 2003 | 01:25 AM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: California drivers: front license plate (nek0)
Had more than 5 of those tickets. Three for my old Accord and 2 for my Civic.
Old Apr 6, 2003 | 01:31 AM
Q-OnE's Avatar
Default Re: California drivers: front license plate (GapxGuy)
got one a long time ago. supposed to be 16 inches above the ground and mines was 14 inch. and i got a fix it for it. what a waste of time. lol
Old Apr 6, 2003 | 04:23 AM
SoCal ITR's Avatar
Default Re: California drivers: front license plate (Q-OnE)
I got a ticket for no front plate about 6 months ago.
$10
It sucks, but it could have been worse.
Just put the plate on your bumper and stop worrying about how it looks. It's not worth it when you get pulled over. Don't give them any more reason to pull you over.
Old Apr 6, 2003 | 10:57 AM
built562's Avatar
CALIFORNIA CODES
VEHICLE CODE
SECTION 5200-5206
rear thereof.
follows:
if you read carefully it says attached to the car not sitting in the windshield, when it is sitting in the window it is no way attached to the car, so attached means srewed or bolted or whatever, also while it is in the windhield it is not perfectly visable. so people should leasrn how to read and understand before they say things.
Old Apr 6, 2003 | 11:12 AM
spankey167's Avatar
Default Re: California drivers: front license plate (SoCal ITR)
$10
Its not $10 anymore... i got a fixing ticket driving through Santa Ana and got a fixing ticket for my 8000K HID's being too blue and no license plate... the ticket turned out to be $96... i was like GOD DAMN!!!! And this was at the end of feb... 28th actually damn cops and their tickety quota!!!
[Modified by spankey167, 12:13 PM 4/6/2003]
Old Apr 6, 2003 | 11:18 AM
vtecdc2's Avatar
Default Re: California drivers: front license plate (spankey167)
yup.. i got a fix-it for my clear corners. and it was $91!!!!!!!!!!!!!!!!!!!!1
Old Apr 6, 2003 | 12:07 PM
Q-OnE's Avatar
Default Re: California drivers: front license plate (VTECDC2)
why are people putting they're license plates inside the car on the passenger side. i think its dangerous. i would think if u got in a accident or some type th eplate would fly at the passenger and actually might cut them (in the neck even). if i had a friend that did that i'd make sure that plate is off that area away from me just in case
Old Apr 6, 2003 | 01:33 PM
professorman's Avatar
its not that bad....just put it on the correct way
Old Apr 6, 2003 | 01:41 PM
NiiS's Avatar
Default Re: California drivers: front license plate (Al Bundy)
Why be even more high profile? I do everything I can to keep cops away, if that means I have a front plate, so be it. I roll w/ no cat, I live in Socal, I try to fly everything under the radar...Put the damn plate on
[Modified by sinister, 2:42 PM 4/6/2003]
Old Apr 6, 2003 | 04:51 PM
daonei's Avatar
Default Re: California drivers: front license plate (sinister)
I agree with NrG.
It's not the risk for having the plate on the dash, plus you lose a little visibility from the reflection.
I don't see anything wrong with having it on legit.
Old Apr 6, 2003 | 05:01 PM
SoCal ITR's Avatar
$10
Maybe it depends on where you get it. I got mine up in South Bay.
Old Apr 6, 2003 | 05:17 PM
MTK Kommander's Avatar
yeah thats a chicken **** ticket.. one time i was at some cafe in LA.. came outside and there was a ticket under my windshield wiper.. no front plate.. so i just had one of my cop buddies sign it off for me and sent them my $10.. i hate chicken **** LA cops.. i have never had a front bumper on any of my cars in riverside, and i have never been bothered.. its just the punk *** LAPD..
mrbadwrench
Honda Civic (2001 - 2005)
Oct 27, 2013 06:47 AM
hhibok
Dec 29, 2012 02:03 AM
Agent_EM1
Northwest (Sales)
23
May 4, 2007 02:29 PM
jsantosDC5
11
Aug 26, 2006 12:17 AM
brycerocket
Apr 3, 2003 09:23 AM
