Is this The proper gear?
Old Apr 5, 2003 | 07:17 PM
H.crx-si
Guest
Posts: n/a
Default Is this The proper gear?
Ok decided to do the mini me swap after TONS of research heres my list of gear I need, think I'll be able to get it running properly with this gear? or do I need either a aftermarket Fuel pressure regulator or vtec controller to get the fuelmix right?
Z6 head from a 92-95 Civic Si/Ex
Head gasket, intake gasket, and exaust gasket from 92-95 Civic Si/Ex
Timing belt from 92-95 Civic Si/Ex
Valve cover gasket for a 92-95 Civic Si/Ex
RPM Activated switch
Adjustable Fuel Pressure Regulator, or FPR from 92-95 Civic Si/Ex (unsure if the adjustable fpr is needed)
Old Apr 6, 2003 | 08:12 AM
H.crx-si
Guest
Posts: n/a
Default Re: Is this The proper gear? (H.crx-si)
anyone?
Old Apr 6, 2003 | 08:26 AM
USDM 4G VTEC's Avatar
u dont need the adj FPR
u use the one that its supposed to be for the head...
anyways if u doing a mini me, u basically in a good route.... VAFC will be more desireable... but a MSD switch will do it.. (has me me do a 15.4 without vtec fuel map )
and if u have an Si or HF model then u got all wired bypassed. if u have a DX or STD then u need to do MPFI.. and for the fuel map u use the one on the TB of the Z6 and not the one on the fireewall
Old Apr 6, 2003 | 08:43 AM
H.crx-si
Guest
Posts: n/a
Default Re: Is this The proper gear? (USDM 4G VTEC)
Ok so I should be okay to just hook up my z6 head/intake manifold with the z6 Fuel pressure regulator and it will run okay? I just keep getting people saying "watch out the timing/fuel mix can be a pain to get right"
M-benz
Sep 8, 2012 11:40 AM
efcivic92
Dec 19, 2008 07:09 AM
adnoh90Civic16
Jun 9, 2003 04:05 PM
ZC_Power
May 23, 2003 02:30 PM
