b16a fuel pump?
Old Apr 5, 2003 | 06:40 PM
LD_EGSICK's Avatar
Default b16a fuel pump?
i have a fuel pump from a 95 ls, would it work for my 91 civic si? i htink my fuel pump is dead. or wouldn't it help the motor run even better>?
Old Apr 5, 2003 | 07:01 PM
plastik462003's Avatar
Default Re: b16a fuel pump? (mysiqu)
it should work with some modification, and i don't think it will help the engine at all
Old Apr 5, 2003 | 07:02 PM
LD_EGSICK's Avatar
Default Re: b16a fuel pump? (plastik462003)
i kinda need to know for sure because i think my feul pump right now is not workin
Old Apr 5, 2003 | 10:25 PM
Redline130's Avatar
It will work with some modification to the fuel pump bracket. Other than that, it's essentially a plug and play.
Old Apr 6, 2003 | 04:19 PM
LD_EGSICK's Avatar
Default Re: b16a fuel pump? (Redline130)
has any one done it?
Old Apr 6, 2003 | 07:46 PM
Cory man's Avatar
That FP is basically the same as the EG civic FP. I put an ITR pump which is a GSR FP in my hatch and its a simple swap. The only thing is that the fuel sock doesnt sit as low as the stock piece. This doesnt allow the pump to pick up fuel in the tank when you are low on gas. If I were you and you thinks its your FP get a used civic pump or buy new.
thunderboy
Jun 20, 2011 03:52 PM
airmaxbri
Mar 29, 2010 11:44 AM
jdm206
Aug 29, 2007 04:24 AM
GSR_Hacker
Jul 8, 2002 06:50 PM
