Secondary Intake Solenoid! Where is this on 98 GSR?
I'm trying to wire vtec into my Eg / GSR hybrid!
I need to know where the IAB (Secondary Intake Solenoid - A17 at the p72 ECU)
is either on the motor or at the engine harnesses.
Can someone post a pic of this please!
Here is my thread over in the Hybrid forum about wiring vtec if interested:
https://honda-tech.com/zerothread?id=462306
Thanks for any help you can offer
None of the above.
Last pic.
Look from driver's side, underneath the manifold, right behind that goldish diaphragm with a single vacuum line on it next to the #1 intake runner.
IAB has pink/blue wires on a 2-Pin connector, and I'm pretty sure it's tied into the same sub-harness as the alternator.
[Modified by IN VTEC, 9:57 AM 4/7/2003]
Last pic.
None of the above.
Last pic.
Last pic.
Focker is well hidden beneath the manifold. There are 2 wires coming out the harness and one is pink / blue as you stated. I just took some pics while I was out there and will post for you all tonight or in the morning
I really have to get going for work.
Fuster_Cluck
Apr 10, 2003 05:24 PM
