Installed AEM FPR and now have some problems!
Old Apr 5, 2003 | 03:35 PM
B2FiNiTY's Avatar
Default Installed AEM FPR and now have some problems!
Everything is installed correctly but there are a few problems.
The setting it comes with is 40psi and I understand that the car's stock settings is 48-55 psi.
Of course this is with the vacuum hose off.
Problems:
1) reading is the same with and without the hose on the fpr!?
2) reading is 58-60psi
I am adjusting it with the hose off and it does not seem to be changing the psi.
Car idles fine, no cel.
Please help
Old Apr 5, 2003 | 03:44 PM
TypeR 01 886's Avatar
Default Re: Installed AEM FPR and now have some problems! (B2FiNiTY)
Well, it does not sound like anything bad becuase you are not noticing any problems. I dont have much ecp with FPRs but if you notice something, then you should start worrying.
Old Apr 5, 2003 | 04:05 PM
B2FiNiTY's Avatar
Default Re: Installed AEM FPR and now have some problems! (TypeR 01 886)
This is just too frustating, I am putting it back to stock
Old Apr 5, 2003 | 05:53 PM
Denny's Avatar
good luck dennis!
Denny: who thinks everything AEM makes, other than intakes, are crap!
Old Apr 5, 2003 | 11:43 PM
sgT's Avatar
sgT
which orifice did you use?
Old Apr 6, 2003 | 06:32 PM
B2FiNiTY's Avatar
Default Re: Installed AEM FPR and now have some problems! (sgT)
The regular orifice it came with. I believe it is the .15 one.
Non-silver, non gold.
I took it off because it was all acting up. Everything is fine right now.
Old Apr 9, 2003 | 09:11 PM
B2FiNiTY's Avatar
Update: Going to call AEM tommorow. Hopefully someone can help me
riddlinkid1986
Jun 28, 2008 05:32 PM
fangtl
Jan 13, 2005 06:21 PM
