empty spot in my fusebox?
I noticed an empty spot in my underhood fusebox, but it has terminals in there for a fuse. I'm wondering if I could connect my sub amp power wire (only 10 gage) to the fusebox and stick the fuse in there? I like everything in my engine bay to look like it was original and came that way.
You probably could. You'd have to find its terminals on the bottom side. I wired my 2nd cig lighter this way using an empty underdash fuse slot.
why does it have to be less than 1 foot away? The stock fuses are more than 1 foot away, aren't they?
Edit: to answer your question, it's because there's more current going through an amp power wire then on the stock 18-22 gauge wire.
[Modified by sjracer, 8:36 PM 4/6/2003]
The fuse is there to protect the wire, you should have a fuse protecting the amp as near as possible to the amp. Some amps have their own fuse built in.
JohnnyEF
Audio / Security / Video
Nov 15, 2006 08:40 PM
