Type R Oil cooler nippe - - TORQUE SPECS!
hmm can you fit a socket over it.. i cant really tell from the pic. but in the helms usually all the 10mm, 14mm and so on have really similar torque specs. but you would also need to know the thread size too.
that will give you an idea of the torque.. but if you need the exact spec, honda dealer should be the key
[Modified by baonest, 9:02 PM 4/7/2003]
