help quick question what in the compression supposed to be on a 96 LS motor
Old Apr 5, 2003 | 12:03 PM
b18c195's Avatar
Default what compression for each cylinder when i do a compression test
Like the question says what is the compression supposed to be on a 96 intergra ls motor. When i do a compression test on this what are the numbers supposed to be.
Please i need to know.
thanks
[Modified by b18c195, 7:17 AM 4/6/2003]
Old Apr 5, 2003 | 09:30 PM
Weston's Avatar
Default Re: help quick question what in the compression supposed to be on a 96 LS motor (b18c195)
9.2:1
Or are you talking about a compression test?
Old Apr 5, 2003 | 10:18 PM
b18c195's Avatar
Default Re: help quick question what in the compression supposed to be on a 96 LS motor (Weston)
ya sorry i meant the compression test
Old Apr 6, 2003 | 07:08 AM
non-VTEC's Avatar
Default Re: what compression for each cylinder when i do a compression test (b18c195)
they range anywhere from 160-200psi per cylinder...........every engine is diffrent so the results will vary.
Old Apr 6, 2003 | 07:37 AM
Audi A4's Avatar
Default Re: what compression for each cylinder when i do a compression test (non-VTEC)
yeah the cylinders may vary as well. could get 170 in#1 and the 125 in #2.
89hatcher
May 29, 2006 02:41 PM
mr_mbuna
Aug 14, 2003 06:41 PM
98cwtypeR
Jun 4, 2003 10:29 PM
57one
Aug 14, 2002 05:06 AM
