Front suspension install quesiton
Old Apr 5, 2003 | 10:00 AM
Zulu888's Avatar
Default Front suspension install quesiton
me and my buddy are installing a set of springs/shocks onto someone else's 94 RS and I just had a quick question. When removing the front strut assembly, do you need to remove the bolts that hold in the front stabilizer bar? Cause in this Hayne's manual I have it says to do so in the instructions but in numerous internet sites with directions, it says you don't have to. But if you don't, how can u push down on that whole rotar/brake assembly thing to loosen out the shock??
Old Apr 5, 2003 | 10:10 AM
neo1z's Avatar
Default Re: Front suspension install quesiton (Zulu888)
Hmm --- Do you mean the front strut bar or the front sway bar?
If you mean the sway, then no. If you mean the strut bar, then of course, because you need to get the strut bolts off.
Old Apr 5, 2003 | 10:40 AM
Zulu888's Avatar
Default Re: Front suspension install quesiton (neo1z)
yeah i mean the sway bar, underneath the car..
but i don't see how u can take out the shocks without removing the bolts for the bar?
Old Apr 5, 2003 | 12:26 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I didn't unbolt my front sway bar, and I didn't have too much trouble at all.
Old Apr 5, 2003 | 12:43 PM
sys3rror's Avatar
Default Re: Front suspension install quesiton (PatrickGSR94)
http://www.team-integra.net/sections...?ArticleID=494
how to article on TI w/ pictures
Old Apr 5, 2003 | 12:49 PM
neo1z's Avatar
Default Re: Front suspension install quesiton (sys3rror)
Ah you did mean the sway - I had no problem getting the fronts done with the front sway still in tact.
Old Apr 5, 2003 | 02:00 PM
VTECorona's Avatar
I didn't take mine out, install went fine. Haynes sucks man, I've found either false info or lack of info a few times.
DarkTeg94
Jan 12, 2005 08:04 PM
noob with an RS
Nov 13, 2004 01:28 PM
rodimus
Jul 30, 2002 10:08 PM
Calavera
Oct 15, 2001 02:03 PM
IgniteTeg
Sep 11, 2001 02:02 PM
