Ball Joint Camber Kits for 90-97 Acccords
Sup guys.
Do any of u guys know of a brand that offers ball joint camber kits for 92 honda accord... right now im using the pivot joint camber kits but then it pushes out the control arms and it hits against the inner fender wall... although the guys shaved the inside... it still tends to hit and im afraid that if it continues to hit that the control arm will break...as my friends control arm did... so if u guys know any brand that offers ball joint camber kits please post the brand... ide appreciate it. thanx
Specialty products makes a good kit. i've heard mechanics that do alignment say they are a pretty good application. one also said that you have to get them to install it, b/c it has to be on the alignment machine to install it w/ the proper castor. i dunno if that's true or not though.
Sliding Ball Joint - Front - Does One Wheel
Camber Adjustment Range +1.5 to +3.0 degrees - For Cars Lowered 1.5" to 3"
$95
for cars lowerd up to 1.5
$78
$95
$78
i got a 3.25 drop on sprint extremes.. w/ ingalls.. all i did was shave down the contorl arm a bit, and the inner fender. . and no problems.
I have an tanabe coilovers sytem and droped like 2.50" and when i hit those NYC pot holes or bumps and wanted to put camber kit but alot people say it will break and cause alot of damage later on, like the top portion will rest on the wheel causeing my bumper/fender damage is this true ?
spankey167
Apr 19, 2004 08:19 PM
eTec
19
May 21, 2002 04:51 AM
