anyone have knowledge on the 95 del sol a/c bracket
My friend ordered me a 95 del sol a/c bracket from honda. My car is a 95 ex coupe. The motor is a 99 jdm itr. I have heard that the bracket should have a "P54" stamp on it. The one i have says p301410. The part number is
38930-p30-000. My friend says its the right one. I feel like it may not be. Is this the a/c bracket for the 99+si and will this bracket work or way wounldn't it work.
if you plan on using the your a/c, the P30 will NOT work. I wasted $125 on 2 P30 brackets already becasue poeple send them to me saying its the right one I need, but I need the P54. I want to keep my a/c, so I need the P54 bracket.
But if anyone need a P30 bracket, ill sell it cheap.
What's cheaper, a P54 bracket or a used Si or GSR A/C compressor? Is it as simple as just swapping out compressors or will I have "environmental" issues with diconnecting the coolant lines?
I too am the proud owner of a GSR bracket that was sold to me under the guise of a Del Sol piece. Looking for an alternative other than a brand new P54.
well, its a big mess, changing compressors. charge lines are different sizes, and then you have to mess with all the phreon and ****, and then get your new compresser recharged. it won't be cheaper, i gurantee it.
it will be a whole lot easier and cheaper to just find that P54 ac mount bracket. I was lucky to find one for $40 at a junk yard. Call around and see what u get.
save yourself time and headaches. buy a new p54 bracket and sell the p30 bracket. you can put that on but only 1 bolt will line up if you're lucky 2. if you try to replace the a/c condenser lines wont bolt up.
