Are the Gen 2 Toda camgears made out of aluminum? Timing belt shredded
Old Apr 5, 2003 | 05:22 AM
GQ 05YellowEVO8's Avatar
Default Are the Gen 2 Toda camgears made out of aluminum? Timing belt shredded
Guys I was wondering if the Toda Camgears were made out of aluminium?
Currently I have the AEM latest gen cam gears and was wondering if they could cause the timing belt to slip.
which cam gears besides the AEM's are good?
Old Apr 5, 2003 | 05:39 AM
rainmanEK's Avatar
big strong guy
Default Re: Are the Gen 2 Toda camgears made out of aluminum? Timing belt shredded (13 Sec GSR)
Toda = Aluminum
Spoon Or Toda (same thing) Both Have nice gears!
Very easy to read with Vaner (sp?) Scale!
Eric
Old Apr 5, 2003 | 05:45 AM
Tweakmeister's Avatar
what cams?
Old Apr 5, 2003 | 05:48 AM
Dropspeed's Avatar
Most cam gear issues are do to improper installation, I have 5+ years on the same AEM cam gears on 3 different motors and no problems.
Mattj
Old Apr 5, 2003 | 05:55 AM
Default Re: Are the Gen 2 Toda camgears made out of aluminum? Timing belt shredded (Dropspeed)
Mattj
So let me see what could be the problem then...
When I install my timing belt I usually use the coat hanger trick to pull up on the timing belt tensioner to make sure all the slack is taken off. but still, when the motor runs, there is still a lot of flapping going on... Is that normal?
Old Apr 5, 2003 | 05:59 AM
uNF$@#!'s Avatar
as you stated in your earlier thread...i think your spec b's are the issue with a timing belt...
Old Apr 5, 2003 | 07:39 AM
VTHokie's Avatar
Default Re: Are the Gen 2 Toda camgears made out of aluminum? Timing belt shredded (Soup ****)
Make sure the timing belt was tensioned correctly. I had honda install mine and they focked it up. Then Willard installed it correctly and everything was alright.
[Modified by VTHokie, 11:40 AM 4/5/2003]
Old Apr 5, 2003 | 08:32 AM
Shark Tank's Avatar
Default Re: Are the Gen 2 Toda camgears made out of aluminum? Timing belt shredded (VTHokie)
if your belt is still flapping a couple things may be going on.
1) you tensioner is failing and loosens up when the belt is actually moving
2) incorrect installation
Old Apr 5, 2003 | 08:37 AM
What are those arrows pointing to on the pic?
Old Apr 5, 2003 | 08:40 AM
Default Re: Are the Gen 2 Toda camgears made out of aluminum? Timing belt shredded (Shark Tank)
I see...I dont know how the tensioner could be failing. I take the tensioner spring out first then I use the hanger to pull up on the tensioner to take out the slack, then I make sure everything is at TDC, and while pulling up on the tensioner, I rotate the motor several times to make sure that everything lines up each time, while I take the slack out of the belt. After I'm done with that, I just tighten the 14mm timing belt tensioner bolt. After that I just put the tensioner spring back into place.
Hows that method of doing the timing belt?
Old Apr 5, 2003 | 08:59 AM
sgT's Avatar
sgT
coat hangers arent really strong enough to put much tension on it
Old Apr 5, 2003 | 09:05 AM
Default Re: Are the Gen 2 Toda camgears made out of aluminum? Timing belt shredded (sgT)
so what do you recommend then?
Old Apr 5, 2003 | 09:13 AM
sgT's Avatar
sgT
i recommend you upgrade your timing belt if you are worried
Old Apr 5, 2003 | 09:52 AM
Shark Tank's Avatar
a throttle cable wire and a strong guy work great for tighten up the tensioner. i agree with steve on the coat hanger thing. i never do it that way.
hybridmiklo
28
Feb 19, 2007 05:15 PM
Gordon_B16
Feb 4, 2005 02:20 AM
DIYMIKE
Mar 10, 2004 06:48 PM
B18Redline
Dec 23, 2003 12:06 AM
integrasi
Sep 21, 2003 09:30 PM
