What coil overs shouls i get?
Old Apr 4, 2003 | 10:35 PM
AVXHATCH's Avatar
Default What coil overs shouls i get?
Im looking to buy some coil overs, and im wondering which type i should buy, im trying to go for that slamed look rite now. I tried the seach didnt find anything, I heard skunk 2 would giive the slamed look, any suggestions? 88 crx
Old Apr 4, 2003 | 10:41 PM
DiPPeD iN miLk Ej CoUpE's Avatar
Default Re: What coil overs shouls i get? (B16A6rex)
crx doesn't go too low ... ive heard you should go with ground contols instead of skunk 2 for the better ride quality and so on an so
[Modified by TooSlowTogoEF, 7:42 AM 4/5/2003]
Old Apr 5, 2003 | 01:32 AM
E-lude78's Avatar
Ground Control sells a Show Kit that can drop our cars up to 4.5 inches. I called them about it and they said they're decent for daily driving.
Old Apr 5, 2003 | 02:00 AM
jc836's Avatar
As a Skunk2 user-they work for me. You can selectspring rates from them on special order. They too use the Eibach ERS springs in various lengths (6"-8"). Our CRX is set up for SCCA and the minimum ride height is 5". Trust me when I say it is not a lot of fun getting the car on the service rack at the dealership-they have to jack the back end up to clear the arms. As to ride quality-that is up to you and will be determined by the spring rate and shocks you buy. I have nothing bad to say about Ground Control-they rally do build a great product and can easily customize for your needs.
A point here--how low you drop the car will have an effect on several things. A CRX is pretty low to begin with. Another will be ride quality and shock life if you do not properly select the shocks for your setup.
b17a1db2
Jul 22, 2007 09:12 PM
95_red_dc
May 29, 2006 10:15 PM
JustinHoMi
Suspension & Brakes
Dec 13, 2005 10:31 AM
iwouldHITit
Dec 8, 2002 09:37 PM
Max_ED9
14
Dec 7, 2001 07:05 PM
