DA Brake problem, ITR master cyl and booster work on DA chassis?
Old Apr 4, 2003 | 09:35 PM
colt45.5's Avatar
Default DA Brake problem, ITR master cyl and booster work on DA chassis?
I have a 93 DA sedan and my **** just went kapoot. I guess using the porsche 4 POT caliper sped up the wear on my stock stuff.
Anyhow I was curious, can i use the itr booster and master cylinder with no fitment issues in the da chassis?
I can flare and make the lines thats no issue at all for me btw, im just curious if this will work in this car.
I was planning on using the ITR master cylinder and booster, then possibly one of those wilwood adjustable purportioning valves i have extra from another project. I think its necessary for me to get this because of the size of the piston and caliper i have upgraded to. With my stock stuff even in the beginning, i had alot of pedal travel before the brakes grabbed (tight upgrade well worth it with **** booster and master cyl )
I think the booster is the issue, at stops the pedal will slowly move its way towards the floor, and the fluid is still toped off, however the car revs up a little each time you step on the brakes, (a little is conciderable differance compared to my friends identical cars)
Old Apr 4, 2003 | 09:37 PM
colt45.5's Avatar
Default Re: DA Brake problem, ITR master cyl and booster work on DA chassis? (colt45)
wait, i dont need to mess with purportioning, its still the same setup with rear disks duh, so omit the dial a valve from the senario.
Old Apr 5, 2003 | 04:30 AM
dfoxengr's Avatar
whats really going to be the difference from your stock 15/16ths to 1"?
Old Apr 5, 2003 | 07:13 AM
colt45.5's Avatar
Default Re: DA Brake problem, ITR master cyl and booster work on DA chassis? (hybridvteceg)
the same differance honda engineered the two peices for. The type R to my knowledge has bigger calipers. The differance probably feeds the pressure necessary for those larger peices. Now i added the larger 4 POT calipers, so surely im at the same senario IMO.
To my knowledge doesnt the ITR use a larger booster as well? Larger booster will clearly provide more pressure for braking. Its just a large vacum dighaphram, larger the part, larger the pressure, am i right or no?
Old Apr 5, 2003 | 01:13 PM
dfoxengr's Avatar
1/16th " wont make the difference you are hoping for. all it is is the size of the piston that moves fluid through the lines.
Old Apr 6, 2003 | 11:05 AM
colt45.5's Avatar
Soooo...
My question is, will the ITR booster and Master cylinder work. Because the ITR uses a larger booster. The booster is what provides a good deal of the braking force with its ammount of vacum pressure it provides per push of the pedal.
Sooo.
WILL THE ITR BOOSTER AND MASTER CYLINDER FIT IN A DA CHASSIS??
I am aware I will need to flare the fittings and make lines, thats no issue, but will the focker fit in the car with no fitment issues?
I am aware the abs model has a bigger master cylinder, i am aware there is a 15/16th piston, a 13/16th piston, and a 1 inch piston in the gsr and type r. The type r uses a decently larger brake booster (the big black deal), and thats why i was curious in using it. Because clearly it was designed to provide force for the larger R calipers on both the front and rear. I need this pressure for my Porsche calipers, otherwise as i experianced before with a 15 16ths it would travel alot closer to the floor before the braking would become sufficient. Im sorry to seem like an *******, but im not debating here. I just am curious if the part will fit in the car i am using?
[Modified by colt45, 8:11 PM 4/6/2003]
Chance EG
Mar 16, 2018 10:39 AM
joprez
May 7, 2013 02:54 PM
ezza
Mar 20, 2006 09:50 AM
ntensehonda
Dec 20, 2005 02:39 PM
speedevo
Jan 26, 2003 07:12 PM
