B&M Fuel Pressure Regulator
They are ok. I would go with a seperate one if I were you, not one that just sits on top of the stock unit. What kinda car do you have, or is this going onto. I have a brand new AEM one that I will sell you for $105 shipped if you are interested. Thats way lower than you will find anywhere else.
the b&m is going on a integra with a b20/vtec.. i need to up the PSI of fuel that i am getting cuz my car is leaning out big time when i throttle it
believe it or not
summit sells them as well and a lot cheaper
you could get the regulator and gage as well for cheap
but you have to be handy and patient to make it
plus if I was you Ill rather but the aem that they are offering you for
cheap
cheap
i didn't like the AEM that i had. it was too big and close to my strut bar. the factory GSR strut bar. and it ended up breaking the little vacum line, because it sticks strait up. the little metal tip broke off completly. i got an B&M after that and is does the same thing. and it cheaper.
so basically i can get the B&M and there would be no difference in buying the aem but the aem is safer..but performance wise they will both accomplish the same thing??
they will both do the same thing. aem is made from 2 pieces bolted together, and the B&M is made from 2 pieces bolted together. except the AEM is bigger and it has broken on me. so i would say that the B&M is safer. i have had NO problems yet with it. i even cut my stock regulator wrong and it still works good.
go with the B&M. especially if you have a strut bar.
are they really the same? how about adjustments? i always thought that the b&m only lets you raise the pressure while the aem can lower and raise the pressure. i saw a topic on some guy who lowered his fuel pressure w/ his b&m by drilling a very small hole by the diaphragm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sukebei Oni »</TD></TR><TR><TD CLASS="quote"><BLOCKQUOTE>quote:<HR>ar e they really the same? how about adjustments? i always thought that the b&m only lets you raise the pressure while the aem can lower and raise the pressure. i saw a topic on some guy who lowered his fuel pressure w/ his b&m by drilling a very small hole by the diaphragm<HR></BLOCKQUOTE>
why would you want to lower the pressure, and there is and adjustment on the B&M to raise and lower the pressure.</TD></TR></TABLE>
well, i don't have a fuel pressure gauge so i don't know but i'm guessing that my fuel pressure might be too high because i have a walbro 255 lp/h.
i'm trying to get my car tuned in the next 1-2 weeks or so i'm trying to find out what i need for my car to get it tuned properly.
my mods are on my sig. that's pretty much everything i have besides the gauges and little accesories here and there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theory48 »</TD></TR><TR><TD CLASS="quote">are they really the same? how about adjustments? i always thought that the b&m only lets you raise the pressure while the aem can lower and raise the pressure. i saw a topic on some guy who lowered his fuel pressure w/ his b&m by drilling a very small hole by the diaphragm</TD></TR></TABLE>You def can lower and raise your fuel pressure with the B&M.... IMO, they both do they same thing. If you dont mind cutting your stock fpr, just gets the B&M. IT will save you a lot of money. I have never had a problem with mine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sukebei Oni »</TD></TR><TR><TD CLASS="quote">i didn't like the AEM that i had. it was too big and close to my strut bar. the factory GSR strut bar. and it ended up breaking the little vacum line, because it sticks strait up. the little metal tip broke off completly. i got an B&M after that and is does the same thing. and it cheaper. </TD></TR></TABLE>
same thing happened to me. the vacuum thing broke off on mine too. i just got a vortech regulator now. just the one that attaches to the stock regulator. they both worked the same. i'd go ahead and get the b&m
