88 crx b18c swap alternator ?/problem
Old Apr 4, 2003 | 08:15 PM
DOHCarp's Avatar
Default 88 crx b18c swap alternator ?/problem
I need to know can I use the B18c1 alternator which is OBD2 with my OBD1 ecu? I am converting from OBD0 to OBD1 I am using my 1988 crx si engine harness
I need to modify the plug if I can use the alternator, but the problem I am having is the wires on the plug are different colors.
(if you were looking at the plug with the clip on top)
OBD0 plug
BLUE--------------WHITE
WHITE/BLUE---BLACK/YELLOW
OBD2 plug
WHITE/GREEN---BLACK/YELLOW
WHITE/RED-------WHITE BLUE
Does anyone know what wires I match up to what?
I tried to put my OBD0 alternator on but it just wont work does anyone have any suggestions this is the last thing I need to do to finish the swap.
thanks
[Modified by DOHCarp, 5:16 AM 4/5/2003]
Old Apr 5, 2003 | 11:27 AM
DOHCarp's Avatar
Default Re: 88 crx b18c swap alternator ?/problem (DOHCarp)
anybody?
what are my alternatives?
any ideas?
Old Apr 5, 2003 | 06:50 PM
CrxSi10's Avatar
No your obd0 alternator will not work because it won't bolt up. Trust me, I've tried it. All you need to do is resolder the wires and it will work. I've gotten a obd2 alternator with my swap and I was mad at first but then what could you do? I looked at the manual and just solder the wires from my 91 crx si engine harness on to the alternator. If you have the plug then it would be better and cleaner. Email me at xonglor10@attbi.com if you need more help.
Old Apr 5, 2003 | 08:22 PM
DOHCarp's Avatar
Default Re: 88 crx b18c swap alternator ?/problem (CrxSi10)
the only problem with that is I dont knwo what color to match up the wires with? there are 2 of the same color wires, and 2 diff. color wires?
Old Apr 7, 2003 | 08:28 PM
DOHCarp's Avatar
bump
Old Aug 9, 2003 | 07:20 PM
jdm_ef9's Avatar
ttt
Old Aug 10, 2003 | 03:19 AM
Fobtions's Avatar
Default Re: 88 crx b18c swap alternator ?/problem (jdm_ef9)
You dont even need to rewire it, unbolt the sheet metal that covers the plug on the alternator. Then swap the obd1/2 style circuit, with the crx circuit.
makes it a real clean install. If you dont know whut im talking about i can provide pics
Old Aug 22, 2003 | 12:35 PM
civictypenos's Avatar
Default Re: 88 crx b18c swap alternator ?/problem (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">You dont even need to rewire it, unbolt the sheet metal that covers the plug on the alternator. Then swap the obd1/2 style circuit, with the crx circuit.
makes it a real clean install. If you dont know whut im talking about i can provide pics</TD></TR></TABLE>
im having a similar problem,i have no obd 2 plug,its a crx.with a obd2 alt.someone please help.
Old Aug 22, 2003 | 06:24 PM
Fobtions's Avatar
Default Re: 88 crx b18c swap alternator ?/problem (civictypenos)
read my post above.
this works on a ob2 alternator. just use the obd0 circuit that is on the old alternator. nobody will probably do this but it makes things super easy. so go and butt connect it if you want.
Old Aug 22, 2003 | 08:07 PM
i took them apart,theres no way it will interchange,do you have pics or something?
Old Aug 23, 2003 | 02:49 AM
Fobtions's Avatar
i can get em for you, you have to trim the thin metal that surrounds the plug.
Old Aug 23, 2003 | 04:36 AM
on the obd2 alternator,there is no thin metal shround,it is a thick aluminum casing.
turboteg90
Apr 9, 2019 08:13 AM
Alex Preece
Oct 3, 2018 07:36 PM
qpzm12
Nov 6, 2010 05:47 AM
hmtcrxsir
Jan 3, 2010 05:53 AM
dahveed
Jan 14, 2005 07:00 PM
