Goal to run mid 12's or lower on stock USDM block
Guest
Posts: n/a
Aight this is the deal, I hear a lot of people talking **** about 1/4 mile times on an ITR chassis
I see bubblebacks with b20's and b18's running only mid 12's or higher in that light *** car. Their motors fully built and everything.
I got my car partly gutted and running just minor bolt-ons. Jun stage 3 cams, cam gears, AEM CAI, ACT clutch, RC 270's, and JUN ECU, header and exhaust. THATS IT
So what do you guys think?? Possible? Hell yeah right!!! Only
I already ran 13.025 at 104 mph on 15" Bogart slicks
Open to all suggestions and comments!!!
Headwork. Hondata. SMS header. Remove power steering, if you haven't already. Get some motor mount inserts, if you haven't already.
Are you using an aftermarket flywheel? What about the crank pulley?
More compression will really help. Is there some reason you want to keep the bottom end stock?
what header what exhuast?? That may help you out. SMS header might help out, a better exhaust might help (all depending on what your current set up is)
what's your 60ft? and your suspension setup?
(if you use a thinner headgasket or mill the head, be sure to shave the dowels which locate the head onto the block appropriately, or you might mix oil and water as well as lose compression/power, and possibly ruin your engine.)
nice work so far, and good luck.
96+ hatchbacks are only about 300 pounds lighter than an ITR. then you mention yours is stripped
the point is, he's making it sound like the 300 (or even less since his car is stripped) pound difference is supposed to make hatchbacks run low 12's high 11's compared to his 13.xxx
aLLjDMRalf
16
May 26, 2003 08:59 AM
Oh... and what MK says!
