***tranny removal?***
Old Apr 4, 2003 | 01:20 PM
jondancer's Avatar
Default ***tranny removal?***
hey could someone give me some instructions on how to take my tansmission off my engine? does it just unbolt and fall ,do i have to take the starter off the top? or is that mounted to the engine? my motor is a b16a and the tranny is a y1 i already have the axels out i just need to drop the tranny!
thanks alot
Old Apr 4, 2003 | 04:35 PM
Flexmyrex's Avatar
Default Re: ***tranny removal?*** (jondancer)
use jackstands take out axles and intermediate shaft, take out your intake sys, battery, battery bracket, starter, i take out the radiator to make it easier (you dont have to). take all the 17mm bolts on tranny, make sure you get the ones on the rear bracket. take the tranny mount off and put some support under the engine. put a jack under tranny for support and pull the tranny out(takes a couple of tries), make sure you get the shaft out and it clears the pressure plate before u bring the tranny down. your radius arm might be in the way when you bring down the tranny so get it off before , 2 bolts on the lower control arm. have fun
if changing clutch, you;ll need a 12 point 10mm socket to get press plate off
Old Apr 4, 2003 | 04:50 PM
Flexmyrex's Avatar
Default Re: ***tranny removal?*** (flexmyREX)
forgot to mention disconnect shift linkage
Old Apr 5, 2003 | 03:26 AM
jondancer's Avatar
so what to i have to do to get it off from the engine , will it just fall if i unbolt it?
Old Apr 5, 2003 | 06:59 AM
Flexmyrex's Avatar
no it will not fall the guidepins will hold it you have to pull the sucker w force
Old Apr 5, 2003 | 07:23 AM
SiR831's Avatar
How about removing the right stabilizer bar? That gives more clearance for the tranny to drop.
crxpwr1
Sep 23, 2006 12:53 PM
wreckedmyteg
Jul 18, 2004 06:30 AM
triggerX
Apr 24, 2004 12:03 AM
cr-x si
16
Jun 19, 2003 09:13 PM
stRtypR25
Dec 20, 2002 01:35 PM
