People with H&R sports??
Old Apr 4, 2003 | 11:46 AM
-BlueGSR-'s Avatar
Default People with H&R sports??
Did you cut the bumpstops? I know it says not to, but some peoples car look lower than others. And Im not sure if the bumpstops would make a difference.
Old Apr 4, 2003 | 12:34 PM
Aaron M's Avatar
Default Re: People with H&R sports?? (-BlueGSR-)
i cut mine in half.
Old Apr 4, 2003 | 12:37 PM
neo1z's Avatar
Default Re: People with H&R sports?? (SilverB18C1)
i cut mine in half.
Ditto.
Old Apr 4, 2003 | 12:38 PM
PhatboyNYC's Avatar
My car had H&R sports on it already when I bought it from the previous owner so I'm not positive if the bumpstops were cut or not but my car definitely seems lower thans others with the same setup. Even without a front lip, I scrape going up and down driveways.
Old Apr 4, 2003 | 12:44 PM
-BlueGSR-'s Avatar
Default Re: People with H&R sports?? (PhAtBoY Si)
Does it affect the height if you cut them or leave them??
Old Apr 4, 2003 | 01:00 PM
basmasta7's Avatar
i'm not sure (a shop installed mine), but my car does seem lower than it should be for H&R sports.
Old Apr 4, 2003 | 01:38 PM
MachAF's Avatar
Default Re: People with H&R sports?? (basmasta7)
i didn't cut the bumpstops. Said not too so I followed directions.
Old Apr 4, 2003 | 02:29 PM
Smooth-GSR's Avatar
Default Re: People with H&R sports?? (MachAF)
Ditto, said not to so I didn't.
Old Apr 4, 2003 | 02:58 PM
dj ozzyman's Avatar
Default Re: People with H&R sports?? (neo1z)
i cut mine in half.
Ditto.
I third that. Bottom half to be exact.
Old Apr 4, 2003 | 06:25 PM
b18cDC2's Avatar
Default Re: People with H&R sports?? (dj ozzyman)
i cut mine in half.
Ditto.
Me too.
Old Apr 4, 2003 | 08:17 PM
rathead's Avatar
Default Re: People with H&R sports?? (b18cDC2)
does someone have a picture of how they cut it?
Old Apr 4, 2003 | 09:11 PM
Aaron M's Avatar
Default Re: People with H&R sports?? (rathead)
just cut the 2 smallest layers off, and leave the 2 thicker parts on
Old Apr 5, 2003 | 06:57 AM
-BlueGSR-'s Avatar
Old Apr 5, 2003 | 08:18 AM
integraver's Avatar
well the bump stop is SUPPOSED to be cut when ur car is lowered, for a simple reason that the springs are smaller and need more room to move up and donw...
now in the same respect.. we HAVE to cut the bump stop or else.. when u hit a hard bump... ur springs will comprress and the the bumpstop will stop it after a certain amt of compressing and u WONT have full range of motion..
so my advice is CUT UR BUMPSTOP IN HALF... i know this as i had installed my springs myself.. and followed instrcution and DIDNT cut them... later i was hitting hard at bumps and i thoguth it was due to BAD srpings.. actually it was the long bump stop whihc wasnt letting the springs bounce and take the pressure and blahb lbah so plzz CUT the bumpstop in half will be better TRUST ME
Old Apr 5, 2003 | 10:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: People with H&R sports?? (integraver)
You do realize that the H&R springs are designed to be used w/ the fully intact bumpstop, right? If you cut the bumpstops, you could possibly subject the shock to a larger range of motion than it was designed to operate in.
Also, the bumpstop has NO effect on ride height. If you want to know, this is my car w/ fully intact bumpstops all around:
[Modified by PatrickGSR94, 1:33 PM 4/5/2003]
Old Apr 5, 2003 | 10:42 AM
gwakie's Avatar
Default Re: People with H&R sports?? (PatrickGSR94)
that's dang low for h&r sports. I thought that would what race springs would look like.
Old Apr 5, 2003 | 11:11 AM
-BlueGSR-'s Avatar
Thanks Patrick thats all I wanted to know!
Old Apr 5, 2003 | 12:25 PM
Community Builder
Default Re: People with H&R sports?? (exzeltus)
I'm running Koni Sport shocks with the front perch on the stock height setting, and the rear perch on the lowest setting (15mm lower than stock), so I do get a bit of extra drop in back. The car sat noticeably higher in back w/ the perches at stock height all around, so I adjusted the rear perch to even it out.
I also heard somebody say you get a bit of drop just from the Koni shocks alone, but I'm not so sure about that. I'm going to compare one of mine to a stock shock the next time I'm home.
DrewQ1
Oct 10, 2004 10:57 PM
gimpykid12
Jul 27, 2004 09:22 PM
anngsr
May 3, 2004 01:18 AM
98LS4dr
Mar 20, 2004 12:17 PM
JSR3STS
Feb 4, 2004 05:41 AM
