Alignment Done Today.. Before and After Settings.
Old Apr 4, 2003 | 11:03 AM
Understeer's Avatar
Default Alignment Done Today.. Before and After Settings.
Lowered on:
- H&R Sport Springs
- Koni Yellow Sport Shocks.
Before Alignment (All in degrees):
Front Wheels:
Left Front Camber: -1.69
Right Front Camber: -1.74
Left Front Toe: -0.13
Right Front Toe: 0.06
Rear Wheels:
Left Rear Camber: -1.07
Right Rear Camber: -1.12
Left Rear Toe: 0.43
Right Rear Toe: 0.06
After Alignment Done(All in degrees):
Front Wheels:
Left Front Toe: 0.01
Right Front Toe: 0.01
Rear Wheels:
Left Rear Camber: -1.27
Right Rear Camber: -1.13
Left Rear Toe: 0.09
Right Rear Toe: 0.09
In conclusion, my toe settings were off before alignment and were reset to zero. The rear camber is well within spec (Honda Rear Camber Spec is -2.00 Degrees)
The rear camber did not need shims to correct the camber, as it was well within spec.
The Front camber should be -1.17 degrees from Honda factory spec. As you can see, I'm running about -1.7 degrees of camber in the front.
So for anyone who asks, do I need a camber kit with H&R Sports, I would say no. My camber is not off by much and won't adversely affect tire wear to that much of an extent. Car drives straight and I'm happy.
[Modified by Understeer, 12:26 PM 4/4/2003]
Old Apr 4, 2003 | 11:07 AM
EL Vap133's Avatar
Default Re: Alignment Done Today.. Before and After Settings. (Understeer)
Wow, they did a pretty good job. What place was this done at?
Old Apr 4, 2003 | 11:15 AM
WiggiE's Avatar
New User
Default Re: Alignment Done Today.. Before and After Settings. (Vap133)
Nice to see people have factual data to back up their findings.
Old Apr 4, 2003 | 01:50 PM
Understeer's Avatar
Default Re: Alignment Done Today.. Before and After Settings. (WiggiE)
Anyone else?
Old Apr 4, 2003 | 01:57 PM
migs's Avatar
Anyone else?
Anyone else, on what? Your settings, wow, your car is aligned correctly now what was your question?
Old Apr 4, 2003 | 02:41 PM
Understeer's Avatar
Default Re: Alignment Done Today.. Before and After Settings. (Migs)
OK.
I was just curious as to what everyone thinks on the settings.
[Modified by Understeer, 3:41 PM 4/4/2003]
Old Apr 4, 2003 | 02:51 PM
Weston's Avatar
I'm not too knowledgable about alignments, so I have a few Q's... Why don't the left and right have the same camber? And how were they able to adjust the camber on the rear? I thought our camber wasn't adjustable unless you had a camber kit.
Old Apr 4, 2003 | 03:06 PM
neo1z's Avatar
Default Re: Alignment Done Today.. Before and After Settings. (Weston)
I feel like I am the only one in the universe with hardcore bad camber on the H&R sports....
Old Apr 4, 2003 | 06:24 PM
Understeer's Avatar
The weight distribution on the car is not 50/50 on either side thus, one side will be heaver and cause a bit more camber.
The rear camber was not adjusted, but the rear toe was adjusted and I guess toe affects camber as well.
You can adjust the rear camber with washers, which is cheap and effective.
Old Apr 4, 2003 | 06:25 PM
Understeer's Avatar
Default Re: Alignment Done Today.. Before and After Settings. (neo1z)
What are your camber settings?
TurboEM1
Suspension & Brakes
10
Mar 31, 2006 05:12 AM
EJK20R
Suspension & Brakes
Mar 19, 2006 10:26 PM
01CWITR
Aug 6, 2002 05:32 PM
keys
Sep 7, 2001 11:21 AM
