just plain white gauge face covers
i dont like the reverse glw gauges and the other kinds that take all kinds of wiring to install i just want plain white gauge faces
anyone know where i coudl find some?
Here you go:
http://www.slickcar.com/productdetai...ProductID=1137
They're made by NR Automotive. OEM style. I can't seem to find their website though. The way these are installed you have to remove the needles, so they're going to have to be recalibrated somehow.
I know somebody on here has them on their GSR. Maybe he can chime in.
http://www.nrauto.com
all you have to do is just make sure you have a full tank of gas when you change them out. Then put the gas needle at full, and everything else on the bottom (speedo, tach, temp). I had these on my si. they are quality, i took them off because i prefer stock black/amber on the si. they were kinda hard to see in some lights though
I got them in my GSR, you're supposed to get a special tool with the gauges to pull the needles. You also need to cut the old gauges out. The difference between the NR gauges and the stock are the stock were painted on their backsides. The NR's aren't. For example: The stock ITR gauge faces are painted orange and the GSR are painted blue.
