B16 in 1989 crx HF
Old Apr 4, 2003 | 10:01 AM
crxtasy_12's Avatar
Default B16 in 1989 crx HF
Has anyone done a b16 into a crx HF. It is in and runs but it sometimes the engine dies when giving gas. It also backfires once in a while. Is there anything different from doing b16 with an SI (i.e wiring, vacuum lines).
thanks in advance for the help.
Old Apr 4, 2003 | 10:46 AM
hybridmoose's Avatar
Default Re: B16 in 1989 crx HF (crxtasy_12)
I have a B20VTEC in my 89 HF. Make sure you cut wires B9 and B11. For some reason in the Hf only these wires can cause alot of havoc.
Old Apr 4, 2003 | 11:23 AM
Mr Furball's Avatar
Default Re: B16 in 1989 crx HF (hybridmoose)
B9 is the back up light, and that will cause problems if you do not cut it. I don't know what b11 is but call ha sport and they can tell you
Old Apr 4, 2003 | 11:28 AM
REDBARON's Avatar
Default Re: B16 in 1989 crx HF (FURBALL B-16)
What does B11 do?
Old Apr 4, 2003 | 11:29 AM
Default Re: B16 in 1989 crx HF (REDBARON)
Im not sure exactly what B11 does but my hasport wiring diagram says to remove it.
Old Apr 4, 2003 | 08:26 PM
jlicrx's Avatar
B11 is the clutch input switch - reports when clutch is depressed - only on HF, not needed on anything else
QuickRexSi21
77
Sep 12, 2006 10:25 PM
lordhuh
Jul 24, 2002 08:01 AM
Cory man
Dec 9, 2001 02:02 PM
