4G Wagon 4WD rear struts on HB/CRX?
Old Apr 4, 2003 | 09:14 AM
xci_ed6's Avatar
Default 4G Wagon 4WD rear struts on HB/CRX?
I heard this may work, but no autoparts store around here has the wagon ones in stock (special order only) so does anyone know if this works similar to the accord struts up front?
-Dustin
Old Apr 21, 2003 | 12:08 PM
kyle h.'s Avatar
Default Re: 4G Wagon 4WD rear struts on HB/CRX? (Autocratic_1st_Gen)
the wagon struts are longer i believe.
Old May 19, 2003 | 06:20 PM
civicwagonman's Avatar
Default Re: 4G Wagon 4WD rear struts on HB/CRX? (kyle h.)
the wagon struts will work, but you will need the wagon springs also, atleast in the rear, cause the base the spring rests on is lower, and the spring is longer.
Old May 24, 2003 | 06:22 PM
xci_ed6's Avatar
Default Re: 4G Wagon 4WD rear struts on HB/CRX? (civicwagonman)
Is the stroke shorter also (is the top mount closer to the spring perch)?
Thanks.
-Dustin
Old May 24, 2003 | 07:14 PM
HondaRcB's Avatar
I have a full set of shocks/springs off my 90 FWD drive Wagon. You're welcome to them for shipping plus a little money.
Old May 25, 2003 | 03:32 AM
Default Re: 4G Wagon 4WD rear struts on HB/CRX? (HondaRcB)
I think the stroke is a little longer on the civic ones.
EFin' Kyle
Mar 26, 2006 10:00 PM
BAZ
17
Jan 21, 2004 01:26 PM
RineRacing
Jan 15, 2004 11:35 AM
gsober
Sep 17, 2001 08:01 AM
