Sloppy - Shift Linkage
Old Apr 4, 2003 | 07:05 AM
crxman00's Avatar
Default Sloppy - Shift Linkage
My shift linkage feels sloppy as sin. After I am in gear, it just moves left to right like it is in nuetral. I got the polyurethane bushings and still the same feel. Any other ideas
Old Apr 4, 2003 | 07:16 AM
Rob!'s Avatar
Default Re: Sloppy - Shift Linkage (crxman00)
what kind of tranny is it? i have a b16 s1 tranny and i hear "just get used to it because thats just how it is." i dont know what causes this tho.
Old Apr 4, 2003 | 09:33 AM
zCivic's Avatar
Default Re: Sloppy - Shift Linkage (RaceFacer)
Where the shift linkage connects to the shifter lever try tightening that bolt up. I know on most of them it will fix it pretty much, another option may be its loose at the tranny itself
Old Apr 4, 2003 | 09:36 AM
Lord Quaalard's Avatar
Default Re: Sloppy - Shift Linkage (zCivic)
Drive someone's Honda that does not have this play. You will soon realize that you can shift quicker with it. I don't know if you auto-x or not, but it really helps me.
Old Apr 4, 2003 | 09:40 AM
crxtasy_12's Avatar
I don't know what kind of shifter you have but i just recently installed a short shifter and it was sloppy because I didn't put on the spacer lookin things when I bolted it up. I had the bushings already on too. No sloppy shifts for me now.
Old Apr 4, 2003 | 10:58 AM
PhatHardy's Avatar
Default Re: Sloppy - Shift Linkage (crxtasy_12)
geez luiz guys, i can't believe nobody came up with one of the reasons yet. The reason that most of you (and i) have the sloppy linkage is because where the shifter bar actually conects to the transmission there is a pin that needs to be punched in and out, this pin is not in all the way therefore you are only connecting this bar by the bottom part and not at the top part therefore giving you that sloppy feel, this can be fixed by putting the pin in properly.
Old Apr 4, 2003 | 11:00 AM
zCivic's Avatar
Default Re: Sloppy - Shift Linkage (PhatHardy)
yeah it could be the "bitch" pin but I would start at the shifter itself then to the tranny because most of the time its just a loose shift lever (shifter)
Old Apr 4, 2003 | 11:51 AM
blah13's Avatar
bitch pin indeed, I had the entire front end of my car supported by a socket on top of my floor jack trying to punch it out
Old Apr 4, 2003 | 12:59 PM
crxman00's Avatar
Default Re: Sloppy - Shift Linkage (blah13)
it is not the pin or the stabilizer bar I put the linkage on this past weekend when I put the motor back in. It won't hit fifth easily anymore. what will the bolts at the bottom of the shifter affect? I know it is tight but there are no bushings or anything.....
Old Apr 4, 2003 | 02:20 PM
drjondurst's Avatar
You'll have problems getting into gear if you over-tighten that shift lever bolt too.
Old Apr 4, 2003 | 02:32 PM
CRX-RX's Avatar
Default Re: Sloppy - Shift Linkage (drjondurst)
You are gonna need to get any and all bushings that are missing from the factory assembly at the shifter. It probably wouldn't hurt to just replace all of them, including the bolt. It should consist of a rubber washer on the outside, nylon washer, then the metal barrel that the bolt passes through, which whould have four rubbuer o-rings around it and a plastic sleeve around that, and then the two washers on the other side. The most common scenario is people are careless when disassembling the shifter and lose the washers on the outside and don't replace them.
Old Apr 5, 2003 | 12:05 AM
89civicdx's Avatar
Default Re: Sloppy - Shift Linkage (CRX-RX)
above post is right
its the bushing in the bottom of the shifter...if thats bad then your 5th gear will feel like its way over at the glove box
Old Apr 5, 2003 | 09:26 AM
crxman00's Avatar
Default Re: Sloppy - Shift Linkage (89civicdx)
it feels like I hit a wall or bottom out when I try to go to fifth.
UrVtecIsLoud
Jul 26, 2006 07:26 PM
91SiRX
Jun 10, 2005 07:41 PM
vtecpoweredsol
11
May 18, 2005 07:56 PM
BDogggUT34
38
Apr 11, 2005 02:19 PM
SuperCivic
12
May 15, 2002 02:12 PM
