Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Archived search disabled... Swaybar question.
Old Apr 4, 2003 | 06:32 AM
honda93's Avatar
Default Archived search disabled... Swaybar question.
What was the SMALLEST factory (or aftermarket) front swaybar offered for the 92-95 Civics? I know,I've been against front bars for years, but my move to FSP and all the goodies that go with it necessitates a bar...
I'd like a bar of 19mm or less... The right size to increase turn-in and spring rates ever so subtly without the wheel-lift thing.
Anthony Mario" Crea
Old Apr 4, 2003 | 06:46 AM
Willard's Avatar
Default Re: Archived search disabled... Swaybar question. (honda93)
Other than 'no front bar'.... the OE one that will fit = 21mm (AFAIK)
[AFAIK]
[Modified by Willard, 1:24 PM 4/4/2003]
Old Apr 4, 2003 | 06:52 AM
solo-x's Avatar
Default Re: Archived search disabled... Swaybar question. (Willard)
what's wrong with more front spring?
nate-the weird one with an itr front bar
Old Apr 4, 2003 | 06:57 AM
honda93's Avatar
Default Re: Archived search disabled... Swaybar question. (solo-x)
Thought about it but the car is still driven to events and many of the lots we run in aren't smooth at all. I feel there needs to be some sort of compliance in the car and 400# springs should be enough considering I really do have a STREET Prepared car...
Anthony "Mario" Crea
Old Apr 4, 2003 | 07:02 AM
solo-x's Avatar
yeah, street driving does get interesting with more then 400lb front springs. but i'm not suggesting going to 900lb springs either. 450fr will increase your front roll stiffness about the same as a 21mm bar and still not have the down-side of a swaybar making the inside tires light.
nate
Old Apr 4, 2003 | 07:33 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Swaybars can have every bit as much a negative effect on ride quality. Thick enough, they can make going over single-wheel bumps a much harsher experience than, say, 400# springs, as they tie both wheels together. A spring is single-wheel compliant, in that respect.
EDIT: Clarified for solo-x. This is why sleep deprivation is bad for you, boys and girls....
A bar will limit roll better than no bar, so keeping the front closer to flat and keeping more weight on the inside. The tire will feel more lift, but there will be more weight on that side of the car.
--Chris, who is going to fall asleep on his feet if it weren't for the crying baby.
[Modified by madhatter, 3:07 PM 4/4/2003]
Old Apr 4, 2003 | 07:36 AM
solo-x's Avatar
Default Re: Archived search disabled... Swaybar question. (madhatter)
Also, a sway bar does not make the inside wheel lighter, in fact, it pushes the inside wheel down more than running no bar.
huh? :confused: like you said, a swaybar is connected to two wheels. push the outside wheel up, the inside wheel wants to do the same, thus making it "lighter".
nate
edit: and to keep things on topic, i _think_ a front swaybar off a crx hf will fit. talk to chris shenefield.
[Modified by solo-x, 4:38 PM 4/4/2003]
Old Apr 4, 2003 | 08:48 AM
honda93's Avatar
nate
450# springs eh? Not much difference, but then I hadn't factored in wheel rate. Thanks for the help.
Old Apr 4, 2003 | 09:13 AM
whitney's Avatar
Can you get / buy / make an adjustable front bar? A longer lever arm will effectively soften the bar. I have an Excel spreadsheet which helps with these kinds of calculations, if that would help.
Saner performance fabricates custom front bars. They could probably help you out! I believe they advertise in GRM.
I am ignorant about front bars on Hondas, but I have investigated this heavily for other cars, so sorry if it's a dumb question.
Edit - found the link for Saner: http://www.sanerperffab.com/. No affiliation.
[Modified by whitney, 1:14 PM 4/4/2003]
Old Apr 4, 2003 | 09:22 AM
Todd00's Avatar
I said I don't want a title!
You can do the 92-95 FSP Civic update/backdate and put a Civic 4 door LX front sway on your car (with the 4-door control arms). I think that is either 17mm or 19mm.
You can also do the same thing and use the 4-door lower rear control arms because they have the nub for the oem style of rear swaybar, so you could do the ITR rear swaybar (or a GSR rear swaybar if you don't want as much rear bar).
My 93 Dx hatch didn't have any swaybars, and I assume your coupe is the same way.
Old Apr 4, 2003 | 09:28 AM
honda93's Avatar
Default Re: Archived search disabled... Swaybar question. (Todd00)
I did the control arms out back (for the TypeR bar, yes it has the Beaks kit) and I have front ones on the way... Mostly because the polybushings I had are shot and it it actually easier to just replace the entire arm, plus I get the holes now.
Know anybody with the small LX bar?
Old Apr 7, 2003 | 06:25 AM
jasyatz's Avatar
Nope...4th Gen bar on a 5th gen car...won't fit...Will hit the exhaust/tunnel/not wide enough to attach to both front LCA's
Old Apr 7, 2003 | 06:28 AM
jasyatz's Avatar
LX 4dr bar is the same 21MM as the SI and EX bars of the 2/3/and 4dr varieties..
Jeff
efjones9
Suspension & Brakes
Apr 6, 2010 12:11 PM
NitrousB.I.G.
Oct 26, 2005 06:44 PM
43MA
Dec 10, 2002 08:18 AM
solo-x
Nov 3, 2002 05:35 PM
